    Trigger commands with a Tasker HTTP Post action
    Instructions
    10.1k
      Tasker is an application for Android which performs tasks (sets of actions) based on contexts (application, time, date, location, event, gesture) in user-defined profiles or in clickable or timer home screen widgets.
      Now you can create a tasker action that runs a command on your computer via TRIGGERcmd. Here's how:
      In Tasker, under the Tasks tab, tap the + button to add a Task, then give it a name like "Playlist on Family"
      Tap the + button in the Task Edit screen to add an Action to your task.
      Select "Net", then "HTTP Post", then configure them as these screenshots show.
      Server:Port: https://www.triggercmd.com
      Path: api/Tasker?trigger=Calculator&computer=Downstairs
      Data/File: token=(your token from the Instructions page)
      Content Type: application/x-www-form-urlencoded
      Make sure you don't have a carriage return between "token=" and your token from the Instructions page. I made that mistake and it took a while to figure out what I'd done wrong.
      I emailed my token to myself so I could copy/paste it on my Android.
      Tasker lets you export an action as an Android app, so now I can tap an icon on my Android desktop that opens my garage. That's pretty sweet. 🤸🏻 🤸🏿 🤸🏻 🤸🏿 🤸🏻 🤸🏿
      EDIT 9/4/17: Now you can add &params=(your command parameters) to your Path or your Data/File field to pass Tasker variables as command parameters. You have to enable parameters on your commands first.
      TaskerSettings
      ContentType
      • Grant FitzG
        Grant Fitz
        Here's a reference to the old UI using an HTTP Post
        Path: api/Tasker?trigger=Louder&computer=Desktop
        Data/File: token=123xyz
        The new API has these fields. Can you map the above parms to the below parms.
        Method: Post
        URL:
        Headers:
        Query Parameters:
        Body:
        File to Send:
          Russ @Grant Fitz
          @Grant-Fitz, this should work with the new HTTP Request task type:
