    New commands not showing up as devices in the Alexa app
    • Greg LarsenG
      Greg Larsen
      I'm new to Trigger cmd and am still using the free version. I've installed the agent on Windows 11 and created some commands that the Alexa app on Android has found successfully. This morning I tried to add other commands, but they are not showing up as devices in the Alexa app. The old commands still work correctly. What might cause this? Thank you!
      Greg LarsenG 1 Reply Last reply Reply Quote 0
      • Greg LarsenG
        Greg Larsen @Greg Larsen
        @Greg-Larsen Found the answer. I had not added a voice command. I got confused because the interface says it is optional, but it is necessary for Alexa to find the device. Leaving this here in case it helps someone else.
        XanderX 1 Reply Last reply Reply Quote 1
        • XanderX
          Xander @Greg Larsen
          @Greg-Larsen Correct. They are optional should someone want to just use the triggercmd site to set off their actions but absolutely needed for Alexa/Google integration. 👍🏻
          • XanderX
            Xander @Xander
            @Xander I haven't added a command in some time and 😆 had to come back here for old-me to remind now-me what I'd done wrong.
              Russ @Xander
              @Xander did you forget to add a voice word to the command?
              • XanderX
                Xander @Russ
                @Russ 😊 Maaaaaybeeeee
                Added a new option, "Throttle" that, when I go out, turns Off and gives qbittorrent all my bandwidth and, when I come home, turns On and cranks it back.
                (I recently moved to Montreal and opted for a muuuch slower internet package)
                  Russ @Xander
                  @Xander cool idea. 💡
