    Crashing & translocation & ARM
    Mac
    234
    • G
      gajahduduk
      Hi. Just trying this for first time.
      The agent, installed in /Applications/ launches but has now crashed twice when editing commands.
      Also it appears to be running in translocation mode. According to LittleSnitch:
      "The application is running in App Translocation, a macOS security mechanism for apps that are not properly installed. You cannot create permanent rules until you move the application to the Applications folder and launch it from there."
      It is actually running from:
      /private/var/folders/*/TRIGGERcmdAgent.app/Contents/MacOS/TRIGGERcmdAgent
      Also:
      • any chance of an ARM build?
      • how bout option to make the menu bar icon a more standard black & white, with a dark mode?
      • G gajahduduk referenced this topic on
        Russ @gajahduduk
        @gajahduduk, thanks. I'll look into an arm build and the icon change. Not sure why it's crashing. I'm pretty sure I tested it on an M1 arm mac.
        G 1 Reply Last reply Reply Quote 0
        • G
          gajahduduk @Russ
          @Russ thanks. pls check into translocation too.
          Here's a crash log from just now.
            Russ @gajahduduk
            @gajahduduk, thanks. Researching this now.
              Russ @gajahduduk
              @gajahduduk, I built this amd64 (Apple Silicon) version. Would you mind testing it?
              https://agents.triggercmd.com/TRIGGERcmdAgent-arm64.dmg
              • G
                gajahduduk @Russ
                @Russ Hi. Thank you for attempting this. Sorry I had no email notifications turned on, so didn't get this until today.
                Just tried it, there seem to be gatekeeper issues.
                alt text
                normally I can bypass this with a terminal command called xattr. However in this case even that doesn't work.
                usually this has to do with lack of code signing the executable.
                i reinstalled the x64 version and got this, which is expected, and after confirming it launched. note that I did not need to use xattr on this one, but maybe I had previously?
                (Prior to this, today, while adding some new actions, it crashed more than once.)
                alt text
                  Russ @gajahduduk
                  @gajahduduk, thank you for testing it.
                  What MacOS version do you have? I suspect it's v15 (aka Sequoia) because they've made it a little harder to run apps like this.
                  Fortunately you can work around it with these steps:
                  1. Try to run TRIGGERcmdAgent, and click Cancel.
                  2. Open Security and Privacy in Settings.
                  3. Scroll down and click Open Anyway next to TRIGGERcmdAgent.
                  • G
                    gajahduduk @Russ
                    @Russ FYI, the ARM version (1.0.45) is now working. I had tried at least one update of the ARM version since I originally posted this, and it too crashed. given I was working with TC yesterday I tried again. whatever you did and whenever you did it, thanks.
                      Russ @gajahduduk
                      @gajahduduk, that's great. Thank you for testing it and letting me know.
