Installer wont start
Hi - i downloaded the windows agent but when I run the installer noting happens - is it broken by a windows update or something?
@iswasdoes, I just tested the latest version of the installer and it worked for me.
You could try temporarily disabling your antivirus software in case that's blocking it.
Or, please check your tray icons - maybe the TRIGGERcmd icon will be there because it actually installed.
Thanks @Russ. Def not running in system tray. I only have windows antivirus and i tried turning that off but still have the same issue. Nothing appears to be going on in task manager when i click the installer so im really bemused what is nit happening. Tried running as administrator also. Any other ideas?
@iswasdoes, you could try downloading the latest again, or download this older version:
@Russ just to let you know, it was something in windows defender I needed to switch off. Dumb of me but Iām sure Iām not the only dumb one
@iswasdoes, nice. I'm glad you figured it out.
This post is deleted! -
So i think it's issue with Windows Defender ?
@Rob-Turing, I don't know. I use Windows Defender and I wasn't able to reproduce the issue.
With your input, this post could be even better š
