    Installer wont start
    470
    • I
      iswasdoes
      Hi - i downloaded the windows agent but when I run the installer noting happens - is it broken by a windows update or something?
        Russ @iswasdoes
        @iswasdoes, I just tested the latest version of the installer and it worked for me.
        You could try temporarily disabling your antivirus software in case that's blocking it.
        Or, please check your tray icons - maybe the TRIGGERcmd icon will be there because it actually installed.
        I 1 Reply Last reply Reply Quote 0
        • I
          iswasdoes @Russ
          Thanks @Russ. Def not running in system tray. I only have windows antivirus and i tried turning that off but still have the same issue. Nothing appears to be going on in task manager when i click the installer so im really bemused what is nit happening. Tried running as administrator also. Any other ideas?
            Russ @iswasdoes
            @iswasdoes, you could try downloading the latest again, or download this older version:
            https://agents.triggercmd.com/TRIGGERcmdAgentSetup31.exe
            I Bob CorlessB 2 Replies Last reply Reply Quote 0
            • I
              iswasdoes @Russ
              @Russ just to let you know, it was something in windows defender I needed to switch off. Dumb of me but I’m sure I’m not the only dumb one 🙂
                Russ @iswasdoes
                @iswasdoes, nice. I'm glad you figured it out.
                • Bob CorlessB
                  Bob Corless @Russ
                  • Rob TuringR
                    Rob Turing
                    So i think it's issue with Windows Defender ?
                      Russ @Rob Turing
                      @Rob-Turing, I don't know. I use Windows Defender and I wasn't able to reproduce the issue.
