    Not able to run cmd file
    • Paulo AndradeP
      Paulo Andrade
      Hi everyone,
      I´m trying to run a cmd file, when I run from start --> run --> C:\temp\test.cmd the file is openned no problem.
      However wen I put the same command in Triggercmd not happens even I put " at begin and " at end of path.
      Please could someone support me?
      Thanks
        Russ @Paulo Andrade
        @Paulo-Andrade, can you show me the contents of your c:\temp\test.cmd file?
        I created one and tested it. It worked for me. Here are my command settings:
        This is my test.cmd script:
        These are some things you could try:
        Click the green "play" button to see if you can run it locally:
        Make sure the "Ground" field is set to foreground.
        Try a simpler script, like mine above to confirm the script is running.
