    Running Shell Script
    Mac
    1.2k
    • A
      abaratz
      I am seeing strange behavior when running a shell script. I am using foreground. When I run the command from the GUI editor, it doesn't immediately run. If I close the editor and re-open it, the command runs immediately upon reopening the editor. If I try to run the command from Alexa, it doesn't run at all. I have another command that uses pmset and that one runs fine. Any ideas what's happening?
        Russ @abaratz
        @abaratz, that is strange.
        Can you share the script? It might give me a clue.
        A 3 Replies Last reply Reply Quote 0
        • A
          abaratz @Russ
          @Russ Here you go. Thank you.
          #!/bin/bash
          if [ "$1" == "open" ]
          then
          open -a "Slack"
          open -a "Microsoft Outlook"
          open -a "Safari"
          else
          shortcuts run "Quit All Applications"
          pmset sleepnow
          fi
          • A
            abaratz @Russ
            @Russ Actually, I just removed the call to shortcuts and it ran fine. Should I be doing something differently with respect to running a shortcut in the script? Thank you.
            • A
              abaratz @Russ
              @Russ Nevermind :). I just saw another post on running shortcuts. I wrapped the shortcuts call in my shell script inside of a call to AppleScript for running the shortcut and that worked. Sorry to bother you.
                Russ @abaratz
                @abaratz, no problem. I'm glad you got it working.
                Would you mind sharing your final working script?
                • A
                  abaratz @Russ
                  @Russ Sure.
                  Here is the shell script:
                  #!/bin/bash
                  if [ "$1" == "start" ]
                  then
                  open -a "Slack"
                  open -a "Safari"
                  else
                  osascript ~/Smarthome/Closeallapps.scpt
                  pmset sleepnow
                  fi
                  And here is the AppleScript for Closeallapps:
                  tell application "Shortcuts Events"
                  set theResult to run shortcut "Quit All Applications"
                  end tell
