    Run remote commands with an old VCR remote and a Raspberry Pi Zero W
    1 Posts 1 Posters 3.7k Views 1 Watching
      I followed this tutorial to get my Pi Zero W on wifi without even connecting a keyboard and monitor to it.
      I followed this tutorial to get it setup with lirc to run commands when I press corresponding buttons on an old VCR remote.
      I setup the lircrc file to call the TRIGGERcmd API using curl commands when I press those buttons.
      I found the curl commands to be much faster than these commands.
      I also found that some remotes work better than others - like my Window Media Center remote works, but each button alternates between two different IR codes, so it works every other time you press a button. I settled on an old Toshiba VCR remote.
      Picture of the Raspberry Pi Zero with IR receiver connected
      My /etc/lirc/lircrc file looks like this:
        begin
             button = KEY_PLAY
             prog = irexec
             config = export HOME=/root ; /root/triggertest.sh calculator downstairs
        end
        begin
             prog = irexec
             button = KEY_RIGHT
             config = export HOME=/root ; /root/triggertest.sh notepad downstairs
        end
      My /root/triggertest.sh file looks like this:
      #!/bin/sh
      trigger=$1
      computer=$2
      token=`cat /root/.TRIGGERcmdData/token.tkn`
      curl -X POST https://www.triggercmd.com/api/run/triggerSave \
      -H "authorization: Bearer ${token}" \
      -H 'content-type: application/json' \
      -d "{\"computername\":\"${computer}\",\"triggername\":\"${trigger}\"}"
