    Add custom commands or scripts in linux
    5 Posts 3 Posters 2.6k Views 1 Watching
    • J Offline
      j0semm
      Hi there!
      How can you add a new custom commands o scritps in a linux server?
      And how can you add this skills in triggercmd page, for example to say:
        Russ @j0semm
        @j0semm, you can edit your ~/.TRIGGERcmdData/commands.json file to add commands.
        To enable the TRIGGERcmd Smart Home Alexa Skill, you can click the link on the page you took a screenshot of, then enable it from the page that link goes to.
        J 1 Reply Last reply Reply Quote 0
        • J Offline
          j0semm @Russ
          @russ Thank you for your answer, I understand that you can add new commands, but when I try every command individually, always it acts as only one and I can see that is this case (view image)
          for example, I have 4 commands
          But when I try for each one, only works next
          It only has one
          I did not find where to add a new Printable voice command to my server4
            Russ @j0semm
            @j0semm, I see those are all background commands, which will only be added if you're running the agent in background mode, which happens when you install the background service with a command like this:
            sudo sh /usr/lib/triggercmdagent/resources/app/src/installdaemon.sh
            That will install it as a linux service you can view with a command like this:
            The Gnome Editor command probably got added when you ran the agent the first time. You run it in foreground mode the first time to install the token. That Gnome Editor command is a foreground command in the default commands.json file.
            T 1 Reply Last reply Reply Quote 0
            • T Offline
              TI_Gaming_TV @Russ
              This post is deleted!
