    Help - I can't connect to devices with Alexa
    Alexa
    • Víctor MerinoV
      Víctor Merino
      Hello, I have a problem connecting the commands with Alexa. I have commands set in the program on Windows, and running them from the web works fine. But when installing the skill from alexa, and scanning new devices, it doesn't find them and I can't use the commands from alexa. Do you think what can happen?
        Russ @Víctor Merino
        @víctor-merino, please confirm you enabled the "TRIGGERcmd Smart Home" skill.
        That's the only skill that will create an Alexa smart home device for each command that has text in the voice field.
        You also need text in the computer's voice field unless it's your default computer. You set your default computer in your profile and you get to your profile by clicking your name in the upper right.
        • Víctor MerinoV
          Víctor Merino
          Thanks for the reply. At first I did have the other skill activated, but then I realized it wasn't that one, and activated the other one. In the end the problem was that I did not have the computer assigned as Administrator, now that I have assigned it, it has detected the devices, thank you so much
