    Alexa not working
    1.1k
    • E
      esaltat
      Hello Russ,
      I cannot run commands from my echo dot. It seems that the skill is not working. I have a presentation to make today and this is urgent.
      Thanks,
      • E
        esaltat
        I am using the Smart home skill and I have "Devices" tied into the routines. Routines doesn't seem to work. Please help!
        • E
          esaltat
          I got it to work after removing all smart devices and re-discovered all devices. My echo dot has been unplugged for days I'm not sure if that's the reason why smart devices suddenly stopped working.
          Is this some kind of bug? How do we avoid this to happen again? Thanks.
            Russ @esaltat
            @esaltat, your echo dot being unplugged shouldn't had anything to do with it. Is it possible you renamed your computer? That still requires you to delete and re-create your Alexa devices. I'll look into automating that.
            E 1 Reply Last reply Reply Quote 0
            • E
              esaltat @Russ
              @russ
              Yes, I renamed my computer. Thanks for looking into this russ!
                Russ @esaltat
                @esaltat, fyi, I updated the server code so it recreates the associated Alexa devices if you rename a computer.
                So if you rename your computer in the future you won't have that problem.
                • E
                  esaltat @Russ
                  @russ That's awesome! Thanks again for the help!
