    Windows 11 - Multiple issues
    • kellanistK
      kellanist
      Hey there!
      Did some testing on Windows 11 and there are a few issues.
      1. When I try to run the agent "as administrator" from the Start menu, I get a JS error in the main process. "TypeError: Path must be a string"
        Starts fine as the logged in local user. Starts fine when logged in as a user with admin permissions.
      2. There are some weird glitches with the GUI editor. Sometimes the window will freeze, sometime it thinks the mouse is 1 command below where it is. Seems like the mapping is off. Have to quit and restart to fix it. It doesn't like it when you switch to a different window and come back to it.
        Russ @kellanist
        Thanks @kellanist . I'll find a way to run Windows 11 and hopefully reproduce those issues.
        kellanistK 1 Reply Last reply Reply Quote 0
        • kellanistK
          kellanist @Russ
          @Russ If you need any testing done, let me know. I have a couple VMs setup with Win11 and a bare bones PC that I just picked up with it on there that I can use. Happy to help.
          Keep up the awesome work bud!
            Russ @kellanist
            @kellanist, thanks for offering to test. I have Windows 11 on my main PC now.
            I tested running the agent "as administrator" and I didn't see that error. If you have any ideas for how to reproduce it, let me know please. Is it consistent for you?
            I've also had no luck reproducing the GUI editor problems you saw. I switched to a different window and back a few times.
            You have multiple Win11 boxes, so you could help by seeing which ones can reproduce those problems.
            • kellanistK
              kellanist @Russ
              @Russ Wil do! I haven't seen the issue with the UI since the latest Win 11 update. May have been an issue with an earlier build.
