    Mac's open command - too powerful
    Scheduled Pinned Locked Moved Mac
    3 Posts 2 Posters 2.7k Views 1 Watching
      I don't actually recommend this because, as the title suggests, there's a potential security risk here if someone gets ahold of your password or token, but it's still pretty cool to play with and it solved this problem so I thought I'd post it as an example.
      I added a command to my mac that runs the "open" command and enabled parameters.
      Then I used the /triggercmd "slash command" with the TRIGGERcmd Slack app to open Finder to my desktop folder:
      /triggercmd open on mac with ~/Desktop
      Here's the dangerous bit: I also found I could run any arbitrary command on my mac.
      For example I could also run calculator with this command:
      /triggercmd open on mac with -a calculator
      The "open" command is a little too powerful because it lets you run any command. So if you do this, don't give out your token or password to triggercmd.com (it's never a good idea to give those out anyway).
      I warned you but in case you want to do it anyway:
      • Use the GUI editor to add a command called open with open as the command, and enable parameters.
      • Go here and click the Add to Slack button.
      • Go to the Instructions page and copy your token.
      • In Slack, run this slash command to link your Slack account with your TRIGGERcmd account:
           /triggercmd-token [paste your token here]
      • Then run this slash command to test it:
      • Profit.
      If you just want to open Calculator, a safer Slack command would be this, which runs the built-in calculator command on your default computer.
      /triggercmd calculator
      • Felipe MartinsF Offline
        Felipe Martins
        how do i configure "my workspace" on slack?
          Russ @Felipe Martins
          @Felipe-Martins, log into your Slack workspace in a browser, then in the same browser, go here to add the TRIGGERcmd Slack app to your workspace:
          https://www.triggercmd.com/user/auth/slack
          If that doesn't answer your question, let me know and I'll elaborate, and add more details here.
