    Problem: Run Call Of Duty Warzone
    6.6k
    • Arthur OscarA
      Arthur Oscar @Russ
      @Russ ill do it... btw i discovered why your result was returning 0 executing manually to you. try right click on au3 file and execute script as 64bits... after that... even .exe compiled 64bits runs okay.
      • Arthur OscarA
        Arthur Oscar @Russ
        Important information!!!!
        allmost solved problem!!!
        just need to run cod.exe inside SysWOW64 cmd prompt
        but to do this... i need edit cod.bat file
        cod.bat says:
        echo program running >> D:\alexa\cod\cod.log
        start "" c:\Windows\SysWOW64\cmd.exe >> D:\alexa\cod\cod.exe
        exit
        but ofc its not working yet... path is incorrect... there is any way to type the path inside the new cmd window? or... execute cmd from 64bit path directly?
          Russ @Arthur Oscar
          @Arthur-Oscar please try this in your cod.bat:
          c:\Windows\SysWOW64\cmd.exe /c D:\alexa\cod\cod.exe
          That will run your cod.exe in the 32bit cmd.exe in the SysWOW64 folder.
          Arthur OscarA 2 Replies Last reply Reply Quote 0
          • Arthur OscarA
            Arthur Oscar @Russ
            @Russ this way its opening in system32 mode...
            i need to execute those comands in cmd from syswow64.. like this other image
            • Arthur OscarA
              Arthur Oscar @Russ
              I Finally Solve the problem...
              first of all... no .bat is needed. thanks god! hahaha
              1st step:
              configurates to open a link to execute cod.exe (compiled)
              2nd step:
              edit a link icon came from cmd (inside SysWOW64 folder) and put this link inside your folder
              3rd step:
              put the infos as following:
              Files needed:
              cmd.lnk (icon to run by triggercmd)
              cod.au3 (script)
              cod.exe(au3 compiled in 64bits)
              imagesearch.au3
              imagesearchDLL.dll
              that's it...
              Thanks @Russ to the help...
              hope you enjoy @Luiz-Henrique-Dela-Giustina and all the others!
              Arthur OscarA 1 Reply Last reply Reply Quote 0
              • Arthur OscarA
                Arthur Oscar @Arthur Oscar
                Forgot to add all the files used
                https://we.tl/t-4w8WHZAPBv
                  Russ @Arthur Oscar
                  @Arthur-Oscar, awesome. I'm glad you got it working! Thanks for sharing your method and your files too.
                  • Marcos BarquetM
                    Marcos Barquet
                    @Arthur-Oscar could you share the files again, thanks!
