Google your parameters
You can google your parameters with a batch file like this:
start https://www.google.com/search?q=%1%%20%2%%20%3%%20%4%%20%5%%20%6%%20%7
You need a double % because a batch file would interpret %20 as your second parameter plus 0. The double % tells it you want %20 which is the URL code for a space.
is this the same on Mac
@jmcgoverndesign, no that's a batch file which only works on a PC.
Macs use bash scripts instead.
This script should open Google in Safari:
#!/bin/bash open -a Safari http://google.com
This script takes parameters, and should work similarly to the Windows batch file that googles your parameters:
#!/bin/bash open -a Safari http://google.com/search?q=$1%20$2%20$3%20$4
I tested it that and it worked for me.
in linux you can use this
#!/bin/bash busqueda=$@ google-chrome https://www.google.com/search?q=${busqueda// /+}
R Russ referenced this topic on
