    Google your parameters
    3.1k
      You can google your parameters with a batch file like this:
      start https://www.google.com/search?q=%1%%20%2%%20%3%%20%4%%20%5%%20%6%%20%7
      You need a double % because a batch file would interpret %20 as your second parameter plus 0. The double % tells it you want %20 which is the URL code for a space.
        A Former User
        is this the same on Mac
          Russ @A Former User
          @jmcgoverndesign, no that's a batch file which only works on a PC.
          Macs use bash scripts instead.
          This script should open Google in Safari:
          #!/bin/bash
          open -a Safari http://google.com
          This script takes parameters, and should work similarly to the Windows batch file that googles your parameters:
          #!/bin/bash
          open -a Safari http://google.com/search?q=$1%20$2%20$3%20$4
          I tested it that and it worked for me.
          • Wladimir PerezW
            Wladimir Perez
            in linux you can use this
            #!/bin/bash
            busqueda=$@
            google-chrome https://www.google.com/search?q=${busqueda// /+}
