    Why the website doesn't show my triggers created?
    • Jimmy David Rodriguez FarfanJ
      I installed triggercmd in my PC and created a new trigger to shutdown my pc, but this new trigger doesn't appear in my website and when I want to conect my trigger with Alexa, she can't reconize my triggers. Can you help me with my problem?
        Russ @Jimmy David Rodriguez Farfan
        @Jimmy-David-Rodriguez-Farfan, that might happen if the Ground field of your new trigger is set to background and you haven't installed the background service. If that's the case, please try changing it to a foreground trigger.
        Are you seeing other commands on the website? Like the default Notepad and Calculator commands?
