    2. Jimmy David Rodriguez Farfan
    Jimmy David Rodriguez FarfanJ Offline
    • Posts 7
    @Jimmy David Rodriguez Farfan
    Jimmy David Rodriguez Farfan Unfollow Follow
    • RE: My triggers doesn't apper in the website
      Thanks Russ for you help, I change the ground and automatically my trigger appeared on the website. Thanks! Now my trigger is working correclly.
      OK Russ thanks, I changed Groud option, but I have a little question the service doesn't appear inside https://www.triggercmd.com/ why the service doesn't start correctlly? or is for other reason?
      I tried to unistalling and reinstalling some times but the result was the same, my windows version is windows 10 here the specific version: https://prnt.sc/10evvwb.
      Russ sorry but i don't know how can set the command to foreground do you have any information to set the command?
      Thanks!
      and if you know other possibility to try, thanks!
      Russ I know what is the problem, after some seconds my service stop automatically this is the log:
      C:\Users\Acer 2\AppData\Local\TRIGGERcmdAgent\app-1.0.25\resources\app\src\service.js stopped running.
      Restarted 4500 msecs after unexpected exit; attempts = 2
      Child process [868 - C:\Users\Acer 2\AppData\Local\TRIGGERcmdAgent\app-1.0.25\resources\app\src\node.exe --harmony "C:\Users\Acer 2\AppData\Local\TRIGGERcmdAgent\app-1.0.25\resources\app\node_modules\node-windows\lib\wrapper.js" --file "C:\Users\Acer 2\AppData\Local\TRIGGERcmdAgent\app-1.0.25\resources\app\src\service.js" --log "TRIGGERcmdAgent wrapper" --grow 0.5 --wait 2 --maxrestarts 3 --abortonerror n --stopparentfirst undefined] finished with 1
      Do you know what is the problem??
      Thaks Russ for your fast answer but my backgroud service is running how you can see in the follow image: https://prnt.sc/10e4u5a.
      Do you know other posibility?
      Thanks!
    • My triggers doesn't apper in the website
      Hello, I have a problem with my triggers, doesn't apper in the website I have windows 10
    • Why the website doesn't show my triggers created?
      I installed triggercmd in my PC and created a new trigger to shutdown my pc, but this new trigger doesn't appear in my website and when I want to conect my trigger with Alexa, she can't reconize my triggers. Can you help me with my problem?
