    Terramaster NAS
    • Seth KazzimS
      Seth Kazzim
      Hi all,
      New to NAS devices, can I use the .deb file to install TriggerCMD onto a NAS?
      Apparently, it needs a .tpk package, so I will be researching how to go from .deb or .dmg to .tpk
      Honestly do not have a clue but I'm sure 24-48hr should be enough.
      Don't need a step by step guide, some links and nudges in the right direction will do.
      I'm only on macOS if that makes a difference.
      Thanks!
        Russ @Seth Kazzim
        @Seth-Kazzim, I see you should be able to log into your Terramaster NAS with SSH:
        https://forum.terra-master.com/en/viewtopic.php?t=268
        If you can login, you could see if you have a dpkg, apt, or rpm command. Then you could try installing the .deb or .rpm. If that doesn't work you could try to install NodeJS. If you can install NodeJS you could download the agent using git from https://github.com/rvmey/TRIGGERcmd-Agent.
        Let me know if you make any progress on any of these fronts and I can give you more ideas.
        Seth KazzimS 1 Reply Last reply Reply Quote 1
        • Seth KazzimS
          Seth Kazzim @Russ
          @Russ Thanks! I've just got the hang of SSH so I'm happy to be building on a recently acquired skillset.
          I will return to update you on my progress.
