    2. Seth Kazzim
    • Best 1
    Seth Kazzim
    @Seth Kazzim
    Seth Kazzim Unfollow Follow
    Best posts made by Seth Kazzim
    • Turn your VPN on/off
      I'm using Merlin atm, so the command below will work.
      ssh router-admin-name@router-ip service stop_vpnclient1
      ssh router-admin-name@router-ip service start_vpnclient1
      You will need to turn off allow password login and generate/add the keys from your machine.
      But it works well. I will write up a full guide, only took me about a day to figure out so it can't be that hard.
      posted in Example Commands
      Seth KazzimS
      Seth Kazzim
    Latest posts made by Seth Kazzim
    • RE: Turn your VPN on/off
      Thanks for that tip, Scott.
      I will add that to my guide on r/SmartHome.
      Seth KazzimS
      Seth Kazzim
    • RE: Terramaster NAS
      @Russ Thanks! I've just got the hang of SSH so I'm happy to be building on a recently acquired skillset.
      I will return to update you on my progress.
      Seth KazzimS
      Seth Kazzim
    • Terramaster NAS
      Hi all,
      New to NAS devices, can I use the .deb file to install TriggerCMD onto a NAS?
      Apparently, it needs a .tpk package, so I will be researching how to go from .deb or .dmg to .tpk
      Honestly do not have a clue but I'm sure 24-48hr should be enough.
      Don't need a step by step guide, some links and nudges in the right direction will do.
      I'm only on macOS if that makes a difference.
      Thanks!
      Seth KazzimS
      Seth Kazzim
      Seth KazzimS
      Seth Kazzim
