    Command to change screen.
    • Ricardo PereiraR
      Ricardo Pereira
      I currently use a monitor and a television, I would like to create a command to open a netflix and change the screen of my monitor, for my television.
        Russ @Ricardo Pereira
        @Ricardo-Pereira you could try this tool from Nirsoft:
        http://www.nirsoft.net/utils/multi_monitor_tool.html
        Example - move all windows from monitor 1 to 2:
        multimonitortool.exe /MoveWindow 2 All 1
        So your command would need to run a batch file (like c:\scripts\NetflixScreen2.bat) that opens Netflix, then moves it to the other screen. Something like this:
        start netflix:
        Ricardo PereiraR 1 Reply Last reply Reply Quote 0
        • Ricardo PereiraR
          Ricardo Pereira
          This post is deleted!
          • Ricardo PereiraR
            Ricardo Pereira @Russ
            which command I use for full screen on netflix ?
            • XanderX
              Xander
              The page that Russ linked has all the commands and syntax for it. Scroll down.
