    YOUR Alexa/Google Assistant account to YOUR TRIGGERcmd account
    Instructions
    troubleshooting alexa google assistan google home hub
    1.2k
      If you two Amazon Alexa accounts link to the same TRIGGERcmd account, or if two Google Assistant accounts link to the same TRIGGERcmd account, you'll have a problem. To solve it, you should unlink both accounts from your TRIGGERcmd account, then link the correct account.
      If you use Google Assistant's voice match feature for instance, this is the proper way to allow multiple people to trigger your commands.
      • tuicemenT
        tuicemen @Russ
        @russ Just a couple questions.
        1: I have both a Google mini (used in the kitchen) and several amazon dots. Currently I only use Alexa with TRIGGERcmd
        After reading this I though I best check if both can be used on the same account?
        2: I have a off grid cabin which I have another Amazon dot but on a different Amazon account. This location also has a Raspi which is used for remote control of things. Do I need a separate TRIGGERcmd account for this location? I assume I do.
          Russ @tuicemen
          @tuicemen, good questions.
          1. You can link 1 Google account AND 1 Amazon account simultaneously to 1 TRIGGERcmd account.
          2. Yes, if you use 2 Amazon accounts you'll need 2 TRIGGERcmd accounts.
