    Routines not triggering anymore
    Alexa
    • Matthew MasonM
      Matthew Mason
      Alexa routines that have a TriggerCMD device as their trigger seem to no longer fire when the TriggerCMD device is turned on from within Alexa.
      For example, I have a TriggerCMD device with voice name “Reset Volumes”, and an Alexa routine with the trigger “When Reset Volumes is pressed”. If I turn Reset Volumes on or off in the Alexa app, it used to trigger the routine. But now the routine will only fire if I trigger Reset Volumes from the TriggerCMD website or API. Turing Reset Volumes on or off in the Alexa app still runs the command (simply an echo in my case) each time, so that functionality is not broken. It just doesn’t seem to trigger any “When <device> is pressed” routines anymore. Is this intentional?
        Russ @Matthew Mason
        @Matthew-Mason, thank you for reporting this.
        I was trying to avoid a loop that one user created, so I disabled the Alexa smart home "doorbell" press when the trigger source was an Alexa Smart Home device trigger.
        It was intentional, but in hindsight it was the wrong way to fix it so I reverted the change. It should work now.
        I'll find a better way to avoid the loop.
        Matthew MasonM 1 Reply Last reply Reply Quote 0
        • Matthew MasonM
          Matthew Mason @Russ
          @Russ, thank you for such a quick response!
          That’s kind of what I suspected happened — fix one user’s edge case and it breaks another’s preferred behavior.
          If you end up having to return to this behavior to avoid routines triggering themselves, I’m sure I can find a way to work around it. But I don’t know how many others are using TriggerCMD’s Alexa Smart Home device to trigger Alexa routines.
            Russ @Matthew Mason
            @Matthew-Mason, it's a good use case that I should not disable, so I'm glad you caught it.
