    TriggerCMDAgent gives Errors when shutting down PC
    • Furkan CevikF
      Furkan Cevik
      As title says:
      https://imgur.com/a/ejEZv65
      Sometimes when shutting down my PC, i get this weird error from TriggerCMD.
      Any ideas why?
      Furkan
        Russ @Furkan Cevik
        @Furkan-Cevik, thank you for reporting it. I have a theory about what's causing it, and I'll produce a new agent version soon.
        Furkan CevikF 1 Reply Last reply Reply Quote 1
        • Furkan CevikF
          Furkan Cevik @Russ
          @Russ ty!
            Russ @Furkan Cevik
            @Furkan-Cevik, you're welcome. I just published version 1.0.48. I hope that fixes it, but please tell me if you see it again after upgrading.
            Zaydel JiménezZ 1 Reply Last reply Reply Quote 0
            • Zaydel JiménezZ
              Zaydel Jiménez @Russ
              @Russ where i can get the 1.0.48 version? I'm getting the same error of this thread on the latest download on main page installer
                Russ @Zaydel Jiménez
                @Zaydel-Jiménez, please confirm, you're seeing the "A break point has been reached" error during Windows shutdown? If so, can you get a picture of that error like Furkan did, it might help me. Also, if it happens every time or only once in a while it would also help me to know that.
                I couldn't find the old 1.0.48 version but I don't think it will be any better in terms of that error than the latest version 1.0.50 because it contains the same code I thought would fix it. It's a tricky problem to fix because I can't reproduce it myself.
                FYI, these are the version notes:
                https://www.triggercmd.com/forum/topic/14/triggercmd-agent-versions
