    Trigger a command with a Shortcut via Siri
    Mac
    2.1k
      You can run commands on your computers with Siri using a Shortcut. Here's how:
      1. Download the Shortcuts app on your iOS device.
      2. Open this link or scan this QR code from your iOS device:
      3. Fill in the computer, trigger, and token fields. The params field is optional.
      4. In the shortcut's settings, tap "Add to Siri" and record your personal phrase.
      Here's a Youtube video showing how it works:
      https://youtu.be/YBOiWBokal8
      • G
        gajahduduk
        hi -- how can this be used to display or say the result?
        here's a command that works on alexa:
        osascript -e 'tell application "Music" to set result to "This song is " & name of current track & " by " & artist of current track & " on the " & year of current track & " album " & album of current track' | sed 's/^/"/;s/$/"/' | xargs -I{} ~/.TRIGGERcmdData/sendresult.sh {}
        when created with the QR code, the last step is "Get contents of TEXT". result: nothing. I added "Show result <contents of URL>" (defaults to that parameter). result: "no authorization header was found".
          Russ @gajahduduk
          @gajahduduk said in Trigger a command with a Shortcut via Siri:
          Can you help me get started? I tried your command it doesn't seem to work. Is there something I need to do in the Music app first?
          russ@macbook-air ~ % osascript -e 'tell application "Music" to set result to "This song is " & name of current track & " by " & artist of current track & " on the " & year of current track & " album " & album of current track'
          60:64: execution error: Can’t make name of «class pTrk» of application "Music" into type Unicode text. (-1700)
          • G
            gajahduduk @Russ
            @Russ i think your Music app's player state is stopped. play a track, or play one and pause it, and it should work. (mine is never stopped :).
            to test the basic functionality leave out the last pipe part (" | xargs" …), and run the rest in Terminal.
            as noted, this works for the "original" Alexa. Since I've been having problems with Alexa Plus and TriggerCMD, I was trying the Shortcuts route.
              Russ @gajahduduk
              @gajahduduk, the sendresult.sh script is not executable by default, so you could probably solve it by running this:
              chmod +x ~/.TRIGGERcmdData/sendresult.sh
              Or make your command:
              osascript -e 'tell application "Music" to set result to "This song is " & name of current track & " by " & artist of current track & " on the " & year of current track & " album " & album of current track' | sed 's/^/"/;s/$/"/' | xargs -I{} bash ~/.TRIGGERcmdData/sendresult.sh {}
              If you run a command like this:
              curl 'https://TRIGGERcmd.com/api/run/trigger?computer=maclaptop&trigger=result&token=(your token)'
              ... and your command has {{result}} in the Voice Reply field, you'll get a response like this:
              {"message":"Trigger sent.  Result was: YOURRESULT"}
              So your Shortcut will need to parse that message using "Get Dictionary Value".
              This post has some detail about it.
              EDIT: I changed that response to the following to make it easier to get the command's result.
              {"message":"Trigger sent.  Result was: YOURRESULT", "result":"YOURRESULT"}
              • G
                gajahduduk @Russ
                @Russ brilliant! yes, I had made sendresult.sh executable previously. but the response change made parsing the result easier as you say. other stumbling blocks fixed:
                • the trigger value in the shortcut configuration needed a "%20" instead of a space, as the command name had a space!
                • the value for "computer" has to be the actual computer name in TriggerCMD, not laptop or maclaptop etc. (DUH).
                • then what I needed in the first steps of the shortcut was this:
                … etc. (you need to work with the variable "dictionary value" in this case.)
                  Russ @gajahduduk
                  Nice @gajahduduk. I'm glad you got it working. Thanks for sharing your use-case.
