    How to run commands from Home Assistant
    Scheduled Pinned Locked Moved Home Assistant
    15 Posts 6 Posters 15.0k Views 4 Watching
    • R Offline
      rafastanger
      I can get the commands to be executed by Alexa, but when I try to make the call directly through the Home Assistant, I get the error: Status Code 400
      Does the call syntax remain the same?
        Russ @rafastanger
        @rafastanger, that should still work, but you can also use this "get" method below. One thing to note - your trigger and computer values can be different from your voice words you'd use with Alexa.
        rest_command:
          triggercmd_calculator:
            url: 'https://www.triggercmd.com/api/run/triggerSave?trigger=calculator&computer=russhp&token=(your token)'
            method: "get"
        • blizzrdof77B Offline
          blizzrdof77
          Is it possible to pass arguments via this method?
            Russ @blizzrdof77
            @blizzrdof77, good question. Yes, you can add this to your URL or payload to pass parameters:
            &params=(yourParams)
            You can use a space or %20 between parameters if you have multiple parameters to pass, like this:
            &params=(param1)%20(param2)
            blizzrdof77B 1 Reply Last reply Reply Quote 1
              blizzrdof77 @Russ
              @russ Thanks for this, by the way!
              For anyone else using TriggerCMD with Home Assistant, I wrote this helper script with a rest_command that I have found very useful for running commands with parameters (or without parameters).
              Just be sure to change "ADD.YOUR.TRIGGERCMD.TOKEN.HERE" to your token.
              The Script:
              ## -- RUN TRIGGERCMD REST COMMAND
              script:
                run_triggercmd_rest_command:
                  alias: Run TriggerCMD REST Command
                  description: Execute a RESTful command with params and a device using triggercmd.
                  icon: mdi:apple-keyboard-command
                  variables:
                    params: ''
                    token: 'ADD.YOUR.TRIGGERCMD.TOKEN.HERE'
                  fields:
                    trigger:
                      description: The name of the trigger
                      example: Exit Windows Program
                      required: true
                    computer:
                      description: The name of the computer as shown in your computer list on triggercmd.com.
                      example: My Computer Name
                      required: true
                    params:
                      description: Optional args string to pass with the trigger, using a space for multiple params [optional].
                      example: ''
                      required: false
                  sequence:
                  - service: rest_command.tcmd_run_command
                    data:
                      trigger: "{{ trigger }}"
                      computer: "{{ computer }}"
                      params: "{{ params }}"
                      token: "{{ token }}"
              The Rest Command
              ## -- RUN TRIGGERCMD COMMAND
              rest_command:
                tcmd_run_command:
                  url: 'https://www.triggercmd.com/api/run/triggerSave'
                  method: POST
                  content_type: 'application/x-www-form-urlencoded'
                  payload: 'trigger={{trigger|replace(" ","%20")}}&computer={{computer|replace(" ","-")}}&params=+{{params}}&token={{token}}'
              Example Usage
              service: script.run_triggercmd_rest_command
              data:
                trigger: This Is The Trigger Name                 # Literally the name of the command
                computer: My Computer                             # (will render as 'My-Computer')
                params: '--female "Shutdown request confirmed"'   # This has 3 params
              A 1 Reply Last reply Reply Quote 1
              • A Offline
                AZRushFan @blizzrdof77
                @blizzrdof77 @Russ I am new to HA and trying to get this working but not sure if my issue is related to possible syntax changes since 2021. Does this format still apply? Thanks.
                  Russ @AZRushFan
                  @AZRushFan, yes, I just tried it. It worked for me with this text at the end of my configuration.yaml:
                  rest_command:
                      method: "post"
                      content_type: "application/x-www-form-urlencoded"
                      payload: "trigger=calculator&computer=russfam&token=(my token)"
                  That said, would it help if I built an official Home Assistant integration?
                  EDIT 9/15/24: The official TRIGGERcmd integration will be available in next Home Assistant version (2024.10). It's due to be released on 10/2/2024. Please try using it instead of the "RESTful Command" method described above.
                  • RussR Russ moved this topic from Instructions on
                  • A Offline
                    AZRushFan
                    @Russ I am testing out the HA integration for TRIGGERcmd and curious on the best practice when using the switch functionality when triggering a script. In my instance it is a single instance AutoHotkey script so by definition there is no "off"; however, it doesn't trigger the next time I try to run it as the switch is still in the on position in HA. What do you suggest? Thank you.
                      Russ @AZRushFan
                      @AZRushFan, in my experience I've been able to trigger the ON switch many times in a row even though the HA virtual switch status is ON. Are you saying you can't trigger the ON command if the switch is already ON?
                      • A Offline
                        AZRushFan @Russ
                        @Russ well as you mentioned it does indeed. I think I had another issue that was preventing the trigger in HA. Thank you.
                        • R Offline
                          rdaraujo
                          Hello guys,
                          Does Home Assistant integration run commands locally?
                          Is it still limited to 1 command per minute in the free tier?
                            Russ @rdaraujo
                            @rdaraujo, yes, it runs the commands locally without the 1 command per minute limit even if you're not subscribed.
                            • AndruA Offline
                              Andru
                              @Russ, thank you for HA integration, would be really great if it also showed "offline" PC's entities as "unavailable".
                              It would be also very helpful for automations.
                                Russ @Andru
                                @Andru, thanks for the idea. I'll look into it.
