    TriggerCMD on Openwrt
    4 Posts 2 Posters 1.5k Views 1 Watching
    • E Offline
      eromano
      Good evening all,
      I tried to install only the agent on Openwrt by following these steps:
      1. installed packeges: node-npm, git-http
      2. created new folder called gitrepo
        3)into the new folder (gitrepo) I executed the git command: git clone https://github.com/rvmey/TRIGGERcmd-Agent.git
      3. into the subfolder TRIGGERcmd-AgentI executed the command: "node ./src/agent.js --console" to verify missing modules
      4. the missing modules installed with npm have been: socket.io-client, sails.io.js, request, prompt, chokidar
      6)then I executed againg the command: "node ./src/agent.js --console" and inserted the token I obtained these rows:
      Daemon install: false
      Logging in with saved token.
      Checking if the computer exists.
      Local Home Assistant Configuration file not found at /root/.TRIGGERcmdData/home_assistant_config.json
      Local Home Assistant listener is disabled.
      Write backup completed.
      The socket was unable to connect.
      The server may be offline, or the
      socket may have failed authorization
      based on its origin or other factors.
      You may want to check the values of
      sails.config.sockets.onlyAllowOrigins
      or (more rarely) sails.config.sockets.beforeConnect
      in your app.
      More info: https://sailsjs.com/config/sockets
      For help: https://sailsjs.com/support
      Technical details:
      TransportError: websocket error
      at WS.onError (/root/node_modules/engine.io-client/build/cjs/transport.js:48:37)
      at ws.onerror (/root/node_modules/engine.io-client/build/cjs/transports/websocket.js:57:39)
      at callListener (/root/node_modules/ws/lib/event-target.js:290:14)
      at WebSocket.onError (/root/node_modules/ws/lib/event-target.js:230:9)
      at WebSocket.emit (node:events:517:28)
      at emitErrorAndClose (/root/node_modules/ws/lib/websocket.js:1035:13)
      at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
      description: ErrorEvent {
      [Symbol(kTarget)]: WebSocket {
      _events: [Object: null prototype],
      _eventsCount: 4,
      _maxListeners: undefined,
      _binaryType: 'nodebuffer',
      _closeCode: 1006,
      _closeFrameReceived: false,
      _closeFrameSent: false,
      _closeMessage: <Buffer >,
      _closeTimer: null,
      _extensions: {},
      _paused: false,
      _protocol: '',
      _readyState: 2,
      _receiver: null,
      _sender: null,
      _socket: null,
      _bufferedAmount: 0,
      _isServer: false,
      _redirects: 0,
      _autoPong: true,
      _url: 'wss://www.triggercmd.com/engine.io/?EIO=4&transport=websocket',
      _req: [ClientRequest],
      [Symbol(kCapture)]: false
      [Symbol(kType)]: 'error',
      [Symbol(kError)]: Error: Unexpected server response: 404
      at ClientRequest.<anonymous> (/root/node_modules/ws/lib/websocket.js:912:7)
      at ClientRequest.emit (node:events:517:28)
      at HTTPParser.parserOnIncomingClient (node:_http_client:700:27)
      at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17)
      at TLSSocket.socketOnData (node:_http_client:541:22)
      at TLSSocket.emit (node:events:517:28)
      at addChunk (node:internal/streams/readable:368:12)
      at readableAddChunk (node:internal/streams/readable:341:9)
      at Readable.push (node:internal/streams/readable:278:10)
      at TLSWrap.onStreamRead (node:internal/stream_base_commons:190:23),
      [Symbol(kMessage)]: 'Unexpected server response: 404'
      context: undefined,
      type: 'TransportError'
      Computer name for Local Home Assistant listener: null
      Error fetching computer name: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received null
      at Object.writeFile (node:fs:2269:5)
      at /root/gitrepo/TRIGGERcmd-Agent/src/ha.js:120:10
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
      code: 'ERR_INVALID_ARG_TYPE'
      Initiated command removals
      Initiated command adds
      Failed while trying add a trigger.
      ^C
      root@OpenWrt:~/gitrepo/TRIGGERcmd-Agent# node ./src/agent.js --console
      in your app.
      Technical details:
      _eventsCount: 4,
      _closeCode: 1006,
      _closeTimer: null,
      _extensions: {},
      _paused: false,
      _protocol: '',
      _readyState: 2,
      _receiver: null,
      _sender: null,
      _socket: null,
      _bufferedAmount: 0,
      _isServer: false,
      _redirects: 0,
      _autoPong: true,
      context: undefined,
      1. on my account now I can see the openwrt instance but with the red icon and it isn't working.
      Can help me to let daemon working proprly please?
      Thanks for support
      Egidio
        Russ @eromano
        @eromano , give me some time. I'll see if I can make it work on openwrt.
        • E Offline
          eromano @Russ
          @Russ yes sure, thank you
            Russ @eromano
            @eromano, I tried to install OpenWRT on a VMWare VM for a while. I got version 15 installed using an OVA but I couldn't get openssl working, so I couldn't install nodejs etc on it.
            Anyway, I noticed your error output shows it's trying to access a URI that starts with /engine.io . That's not valid URI.
            I wonder if you've upgraded socket.io-client beyond the version specified in ubuntupackage.json because this article says the latest version 'socket.io-client@4.X.X uses /engine.io instead of the valid /socket.io URI.
