    Quick Home Assistant setup with Docker
    Scheduled Pinned Locked Moved Home Assistant
    1 Posts 1 Posters 718 Views 1 Watching
      I wrote this start.sh bash script to run Home Assistant for the Youtube demo but you could also use it to try out Home Assistant and/or the TRIGGERcmd integration for it:
      #!/bin/bash
      mkdir -p ~/ha/config
      docker run -d \
        --name homeassistant \
        --privileged \
        -e TZ=America/Detroit \
        -v ~/ha/config:/config \
        -v /run/dbus:/run/dbus:ro \
        -p 8123:8123 \
        --rm \
        ghcr.io/home-assistant/home-assistant:stable
      This shows my session where I ran it, then confirmed it's running with the docker ps command:
      russ@RussHP:~/ha$ cat start.sh
      #!/bin/bash
      docker run -d \
        --privileged \
        -p 8123:8123 \
        --rm \
      russ@RussHP:~/ha$ ./start.sh
      a32957000a3f029fda67ff1cc2d96b22d2fe4f13125536023e94723a5df2dc6f
      russ@RussHP:~/ha$ docker ps
      CONTAINER ID   IMAGE                                          COMMAND   CREATED       STATUS       PORTS                    NAMES
      59c343cb87fa   ghcr.io/home-assistant/home-assistant:stable   "/init"   2 hours ago   Up 2 hours   0.0.0.0:8123->8123/tcp   homeassistant
      After it was running, I was able to access it at http://localhost:8123
