Powershell script to run commands remotely via TRIGGERcmd
Here's an example Powershell script you could use to call the TRIGGERcmd API to run a remote command:
$postdata = @{ trigger='notepad' computer='Laptop' # params='optionalparameter.txt' } $token=Get-Content ~\.TRIGGERcmdData\token.tkn $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]" $headers.Add("authorization", "Bearer " + $token) $json = $postdata | ConvertTo-Json $response = Invoke-RestMethod 'https://www.triggercmd.com/api/run/triggerSave' -Method Post -Body $json -ContentType 'application/json' -Headers $headers -
R Russ referenced this topic on
@Russ como posso efetuar este comando o powershel?
start microsoft-edge:https://www.xbox.com/pt-BR/play/launch/forza-horizon-5-edição-padrão/9NKX70BBCDRN
$wshell = New-Object -ComObject wscript.shell;
$wshell.AppActivate('edge')
while ($true)
Sleep 2
$wshell.SendKeys('{f11}')
exit
}exit
