    Customer Support? TRIGGERcmdAgent keeps stopping
    30 Posts 2 Posters 9.7k Views 1 Watching
    • Frank MalczewskiF Offline
      Frank Malczewski @Russ
      @Russ Hi Russ. Well, its been a couple of months without any issues UNTIL yesterday, when I noticed I couldn't trigger any lights and checked my server to find: 68245a65-975b-4b72-a531-56a31c084510-image.png
      If you remember, I set it up to restart every week on Sunday.
      I also saw that multiple (3) TRIGGERcmdAGents were showing in the system tray. I had to acknowledge the error and manually restart it.
      Was wondering if you had any other users seeing this happen since spring.
      Frank
        Russ @Frank Malczewski
        @Frank-Malczewski, no, I don't know of anyone else who's had that error yet.
        When I googled for that error I saw multiple suggestions to use this command:
        sfc /scannow
        It might be worth a try.
        I've seen that issue with multiple TRIGGERcmd tray icons - that's from killing the agent and re-running it. When you hover over the icon for one of the processes that was already killed, the icon disappears.
        Frank MalczewskiF 4 Replies Last reply Reply Quote 0
          @Russ Use that command where? In the scheduled task?
          UPDATE - never mind - you meant to run it from a CMD prompt
            @Russ results:
            Beginning verification phase of system scan.
            Verification 100% complete.
            Windows Resource Protection found corrupt files and successfully repaired them.
            For online repairs, details are included in the CBS log file located at
            windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
            repairs, details are included in the log file provided by the /OFFLOGFILE flag.
            C:\windows\system32>
              @Russ Will see if that helped. Thanks.
                @Russ Well, for some odd reason Triggercmd stopped today and I found the following error message which was nothing like the previous failures:
                Might this have been a fluke with Triggercmd stopping or is it related?
                I also think I am going to increase my task scheduler (to stop and restart TRIGGERcmd) to run every day instead of once per week...
                  @Frank-Malczewski, that one is for a different process, so probably not related to the triggercmd agent.
                    @Russ OK. Thanks. As previously mentioned, I am now running that script nightly. Hopefully, even if I get a failure it will be short-lived.
                      Frank Malczewski
                      @Russ Just an update - I have not 'noticed' TRIGGERcmd failing since I started running the script daily. I do occasionally see multiple icons in the system tray that vanish if I hover over them - not sure if they stay after I run the script or if TRIGGERcmd crashed, then my script ran within that 24 hr window and started TRIGGERcmd back up but whichever it is, it has not been an inconvenience2023-10-27 17_40_37-Server - AnyDesk.jpg .
                      Thanks.
                        @Frank-Malczewski, thanks for letting me know. Sorry that's necessary but I'm glad it's working for you. I've seen those extra tray icons before - the icon doesn't get removed when you kill the agent without using the Quit function.
