    80 Posts 2 Posters 31.6k Views 1 Watching
      @Antonio-Francisco-S-Santos, if you don't mind killing all instances of python3, you could use this command:
      killall python3
      You could make that your "Off Command" so when you turn the virtual device off, it runs the killall command.
      {"trigger":"Sonar_barrier.py","command":"/home/pi/TonyPi/Extend/Caminhar.sh","offCommand":"killall python3","ground":"background","voice":"Caminhar","allowParams": "false"}
        @Russ Muito obrigado meu Amigo, ele funciona mas desliga o Robô após fechar o Script. kkkkk
        Na realidade estou querendo fechar só o Script que estar rodando no momento. No caso um outro Script que fecha os outros quando estiver rodando.
          Boa Tarde Professor, Até hoje não conseguir fechar um Script em execução pelo TrigeerCmd, mesmo usando o camando killall não fecha o script sem desligar o
          sistema do raspberry pi
            @Antonio-Francisco-S-Santos, while the python script is running, please run this, then paste the result when you reply:
            ps -ef
            I'm hoping that information will show me a way you can kill your python script.
              @Antonio-Francisco-S-Santos UID PID PPID C STIME TTY TIME CMD
              root 1 0 0 16:44 ? 00:00:04 /sbin/init splash
              root 2 0 0 16:44 ? 00:00:00 [kthreadd]
              root 3 2 0 16:44 ? 00:00:00 [rcu_gp]
              root 4 2 0 16:44 ? 00:00:00 [rcu_par_gp]
              root 8 2 0 16:44 ? 00:00:00 [mm_percpu_wq]
              root 9 2 0 16:44 ? 00:00:00 [rcu_tasks_rude_]
              root 10 2 0 16:44 ? 00:00:00 [rcu_tasks_trace]
              root 11 2 0 16:44 ? 00:00:00 [ksoftirqd/0]
              root 12 2 0 16:44 ? 00:00:07 [rcu_sched]
              root 13 2 0 16:44 ? 00:00:00 [migration/0]
              root 14 2 0 16:44 ? 00:00:00 [cpuhp/0]
              root 15 2 0 16:44 ? 00:00:00 [cpuhp/1]
              root 16 2 0 16:44 ? 00:00:00 [migration/1]
              root 17 2 0 16:44 ? 00:00:00 [ksoftirqd/1]
              root 20 2 0 16:44 ? 00:00:00 [cpuhp/2]
              root 21 2 0 16:44 ? 00:00:00 [migration/2]
              root 22 2 0 16:44 ? 00:00:00 [ksoftirqd/2]
              root 25 2 0 16:44 ? 00:00:00 [cpuhp/3]
              root 26 2 0 16:44 ? 00:00:00 [migration/3]
              root 27 2 0 16:44 ? 00:00:00 [ksoftirqd/3]
              root 29 2 0 16:44 ? 00:00:00 [kworker/3:0H-kblockd]
              root 30 2 0 16:44 ? 00:00:00 [kdevtmpfs]
              root 31 2 0 16:44 ? 00:00:00 [netns]
              root 33 2 0 16:44 ? 00:00:00 [kworker/1:1-events]
              root 34 2 0 16:44 ? 00:00:00 [kauditd]
              root 36 2 0 16:44 ? 00:00:00 [khungtaskd]
              root 37 2 0 16:44 ? 00:00:00 [oom_reaper]
              root 38 2 0 16:44 ? 00:00:00 [writeback]
              root 39 2 0 16:44 ? 00:00:00 [kcompactd0]
              root 59 2 0 16:44 ? 00:00:00 [kblockd]
              root 60 2 0 16:44 ? 00:00:00 [blkcg_punt_bio]
              root 61 2 0 16:44 ? 00:00:00 [watchdogd]
              root 62 2 0 16:44 ? 00:00:00 [kworker/0:1H-mmc_complete]
              root 63 2 0 16:44 ? 00:00:00 [rpciod]
              root 65 2 0 16:44 ? 00:00:00 [xprtiod]
              root 66 2 0 16:44 ? 00:00:00 [kswapd0]
              root 67 2 0 16:44 ? 00:00:00 [nfsiod]
              root 68 2 0 16:44 ? 00:00:00 [kthrotld]
              root 71 2 0 16:44 ? 00:00:00 [iscsi_eh]
              root 72 2 0 16:44 ? 00:00:00 [iscsi_destroy]
              root 73 2 0 16:44 ? 00:00:00 [nvme-wq]
              root 74 2 0 16:44 ? 00:00:00 [nvme-reset-wq]
              root 75 2 0 16:44 ? 00:00:00 [nvme-delete-wq]
              root 78 2 0 16:44 ? 00:00:00 [DWC Notificatio]
              root 79 2 0 16:44 ? 00:00:00 [uas]
              root 80 2 0 16:44 ? 00:00:07 [vchiq-slot/0]
              root 81 2 0 16:44 ? 00:00:00 [vchiq-recy/0]
              root 82 2 0 16:44 ? 00:00:00 [vchiq-sync/0]
              root 83 2 0 16:44 ? 00:00:00 [zswap-shrink]
              root 86 2 0 16:44 ? 00:00:01 [kworker/0:5-mm_percpu_wq]
              root 87 2 0 16:44 ? 00:00:00 [sdhci]
              root 88 2 0 16:44 ? 00:00:00 [irq/49-mmc0]
              root 90 2 0 16:44 ? 00:00:00 [mmc_complete]
              root 91 2 0 16:44 ? 00:00:00 [kworker/1:1H-kblockd]
              root 92 2 0 16:44 ? 00:00:00 [kworker/1:2H-kblockd]
              root 93 2 0 16:44 ? 00:00:00 [jbd2/mmcblk0p2-]
              root 94 2 0 16:44 ? 00:00:00 [ext4-rsv-conver]
              root 97 2 0 16:44 ? 00:00:00 [ipv6_addrconf]
              root 98 2 0 16:44 ? 00:00:00 [kworker/3:2-mm_percpu_wq]
              root 113 2 0 16:44 ? 00:00:00 [kworker/3:2H-kblockd]
              root 115 2 0 16:44 ? 00:00:00 [kworker/2:2H-kblockd]
              root 121 1 0 16:44 ? 00:00:01 /lib/systemd/systemd-journald
              root 160 1 0 16:44 ? 00:00:00 /lib/systemd/systemd-udevd
              root 204 2 0 16:44 ? 00:00:00 [vchiq-keep/0]
              root 207 2 0 16:44 ? 00:00:00 [SMIO]
              root 221 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 223 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 226 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 270 2 0 16:44 ? 00:00:00 [cfg80211]
              root 273 2 0 16:44 ? 00:00:00 [brcmf_wq/mmc1:0]
              root 275 2 0 16:44 ? 00:00:00 [brcmf_wdog/mmc1]
              root 283 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 284 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 285 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              root 286 2 0 16:44 ? 00:00:00 [mmal-vchiq]
              systemd+ 335 1 0 16:44 ? 00:00:00 /lib/systemd/systemd-timesyncd
              root 338 1 0 16:44 ? 00:00:01 /usr/sbin/haveged --Foreground --verbose=1 -w 1024
              root 376 1 0 16:44 ? 00:00:00 /usr/sbin/rsyslogd -n -iNONE
              root 377 1 0 16:44 ? 00:00:04 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
              root 378 1 0 16:44 ? 00:00:00 /usr/sbin/cupsd -l
              root 379 1 0 16:44 ? 00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
              avahi 381 1 0 16:44 ? 00:00:00 avahi-daemon: running [TonyPiPro.local]
              root 382 1 0 16:44 ? 00:00:00 /usr/sbin/ModemManager --filter-policy=strict
              root 383 1 0 16:44 ? 00:00:04 /usr/bin/python3 /home/pi/hiwonder-toolbox/hw_button_scan.py
              root 386 1 0 16:44 ? 00:00:17 /usr/bin/python3 /home/pi/hiwonder-toolbox/hw_wifi.py
              avahi 390 381 0 16:44 ? 00:00:00 avahi-daemon: chroot helper
              message+ 391 1 0 16:44 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
              root 396 1 0 16:44 ? 00:00:00 /usr/sbin/rngd -r /dev/hwrng
              root 401 1 0 16:44 ? 00:00:00 /usr/lib/udisks2/udisksd
              root 402 1 0 16:44 ? 00:00:00 /usr/sbin/cron -f
              root 407 1 0 16:44 ? 00:00:00 /usr/bin/python3 /home/pi/hiwonder-toolbox/hw_remote.py
              root 408 1 3 16:44 ? 00:02:20 /usr/bin/python3 /home/pi/TonyPi/TonyPi.py
              root 410 1 6 16:44 ? 00:04:06 /usr/bin/pigpiod
              nobody 416 1 0 16:44 ? 00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/e
              root 417 1 0 16:44 ? 00:00:00 /lib/systemd/systemd-logind
              root 430 1 0 16:44 ? 00:00:00 /usr/bin/python3 /home/pi/hiwonder-toolbox/hw_find.py -t TONYPIPRO
              root 495 1 0 16:44 ? 00:00:00 /usr/sbin/cups-browsed
              root 505 1 0 16:44 ? 00:00:00 /usr/bin/vncserver-x11-serviced -fg
              root 516 505 0 16:44 ? 00:00:14 /usr/bin/vncserver-x11-core -service
              root 526 1 0 16:44 ? 00:00:00 /usr/sbin/sshd -D
              root 527 1 0 16:44 ? 00:00:00 /usr/lib/policykit-1/polkitd --no-debug
              root 540 1 0 16:44 ? 00:00:00 /usr/sbin/lightdm
              dnsmasq 549 1 0 16:44 ? 00:00:00 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -r /run/dnsmasq/resolv.conf -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg
              root 629 540 2 16:44 tty7 00:01:17 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
              root 634 1 0 16:44 tty1 00:00:00 /bin/login -f
              root 643 1 0 16:44 ? 00:00:00 haveged
              root 659 1 0 16:44 ? 00:00:06 /usr/bin/vncagent service 15
              root 672 1 0 16:44 ? 00:00:00 /sbin/dhcpcd -q -b
              root 691 1 0 16:44 ? 00:00:00 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
              root 711 540 0 16:44 ? 00:00:00 lightdm --session-child 14 17
              pi 716 1 0 16:44 ? 00:00:00 /lib/systemd/systemd --user
              pi 717 716 0 16:44 ? 00:00:00 (sd-pam)
              pi 766 711 0 16:44 ? 00:00:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
              pi 774 716 0 16:44 ? 00:00:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
              pi 833 766 0 16:44 ? 00:00:00 /usr/bin/ssh-agent /usr/bin/im-launch x-session-manager
              pi 864 1 0 16:44 ? 00:00:00 /usr/bin/fcitx -d
              pi 874 1 0 16:44 ? 00:00:00 /usr/bin/dbus-daemon --syslog --fork --print-pid 5 --print-address 7 --config-file /usr/share/fcitx/dbus/daemon.conf
              pi 878 1 0 16:44 ? 00:00:00 /usr/bin/fcitx-dbus-watcher unix:path=/tmp/dbus-Wd5SygDeF8,guid=3bff97bd434c9201ce685dc464710c18 874
              pi 881 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfsd
              pi 886 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
              pi 895 766 0 16:44 ? 00:00:00 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
              pi 898 766 0 16:44 ? 00:00:00 lxpolkit
              pi 904 766 0 16:44 ? 00:00:27 lxpanel --profile LXDE-pi
              pi 905 766 0 16:44 ? 00:00:01 pcmanfm --desktop --profile LXDE-pi
              pi 911 1 0 16:44 ? 00:00:00 /usr/bin/ssh-agent -s
              pi 918 1 0 16:44 ? 00:00:00 /usr/bin/python3 /usr/share/system-config-printer/applet.py
              pi 929 1 0 16:44 ? 00:00:00 /usr/lib/geoclue-2.0/demos/agent
              pi 947 716 0 16:44 ? 00:00:00 /usr/bin/pulseaudio --daemonize=no
              pi 952 1 0 16:44 ? 00:00:00 /usr/bin/vncserverui service 16
              rtkit 969 1 0 16:44 ? 00:00:00 /usr/lib/rtkit/rtkit-daemon
              pi 973 952 0 16:44 ? 00:00:00 /usr/bin/vncserverui -statusicon 5
              pi 974 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
              pi 986 634 0 16:44 tty1 00:00:00 -bash
              pi 990 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
              pi 1006 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
              root 1009 1 0 16:44 ? 00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 460800 noflow -
              root 1010 2 0 16:44 ? 00:00:00 [kworker/u9:1-hci0]
              root 1012 2 0 16:44 ? 00:00:00 [kworker/u9:2-hci0]
              root 1013 1 0 16:44 ? 00:00:00 /usr/bin/python3 /home/pi/TonyPi/Extend/multi_control_server.py
              root 1015 1 0 16:44 ? 00:00:15 /usr/bin/python3 /home/pi/TonyPi/Extend/multi_control_client.py
              root 1017 1 1 16:44 ? 00:00:47 /usr/bin/python3 /home/pi/TonyPi/Joystick.py
              pi 1028 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
              root 1034 1 0 16:44 ? 00:00:00 /usr/lib/bluetooth/bluetoothd
              pi 1040 1 0 16:44 ? 00:00:00 /usr/lib/menu-cache/menu-cached /run/user/1000/menu-cached-:0
              pi 1044 716 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
              root 1049 1 0 16:44 ? 00:00:00 /usr/bin/bluealsa
              root 1056 2 0 16:44 ? 00:00:00 [krfcommd]
              pi 1065 881 0 16:44 ? 00:00:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.5 /org/gtk/gvfs/exec_spaw/0
              lp 1258 378 0 16:44 ? 00:00:00 /usr/lib/cups/notifier/dbus dbus://
              colord 1259 1 0 16:44 ? 00:00:00 /usr/lib/colord/colord
              root 4879 2 0 17:14 ? 00:00:04 [kworker/u8:0-events_unbound]
              root 5969 2 0 17:23 ? 00:00:00 [kworker/3:1]
              root 6382 2 0 17:27 ? 00:00:04 [kworker/u8:1-events_unbound]
              root 6900 2 0 17:31 ? 00:00:00 [kworker/2:1-events]
              pi 6995 904 0 17:32 ? 00:00:00 lxterminal
              pi 7004 6995 0 17:32 pts/0 00:00:00 bash
              root 7082 2 0 17:32 ? 00:00:02 [kworker/u8:2-events_unbound]
              root 7140 526 0 17:33 ? 00:00:00 sshd: pi [priv]
              pi 7158 7140 0 17:33 ? 00:00:00 sshd: pi@pts/1
              pi 7159 7158 0 17:33 pts/1 00:00:00 -bash
              root 7380 2 0 17:35 ? 00:00:00 [kworker/0:2H]
              root 7423 2 0 17:35 ? 00:00:00 [kworker/1:0]
              root 7430 377 0 17:35 ? 00:00:00 /bin/sh -c /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 7431 7430 0 17:35 ? 00:00:00 /bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 7434 7431 99 17:35 ? 00:18:18 /usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py
              root 7456 1 0 17:35 ? 00:00:00 dbus-launch --autolaunch cb12512d764b467aa157bee72a6681fe --binary-syntax --close-stderr
              root 7457 1 0 17:35 ? 00:00:00 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
              root 7470 2 0 17:35 ? 00:00:00 [kworker/2:1H]
              root 7474 2 0 17:35 ? 00:00:01 [kworker/0:2-events]
              root 7583 2 0 17:36 ? 00:00:00 [kworker/2:0-mm_percpu_wq]
              root 7767 377 0 17:37 ? 00:00:00 /bin/sh -c /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 7768 7767 0 17:37 ? 00:00:00 /bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 7771 7768 1 17:37 ? 00:00:05 /usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py
              root 7937 2 0 17:39 ? 00:00:00 [kworker/1:0H]
              root 8114 2 0 17:40 ? 00:00:00 [kworker/0:0-events]
              root 8115 377 0 17:40 ? 00:00:00 /bin/sh -c /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 8116 8115 0 17:40 ? 00:00:00 /bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh
              root 8119 8116 1 17:40 ? 00:00:03 /usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py
              root 8257 2 0 17:41 ? 00:00:00 [kworker/2:2-mm_percpu_wq]
              root 8306 2 0 17:42 ? 00:00:00 [kworker/u8:3-events_unbound]
              root 8343 377 0 17:42 ? 00:00:00 /bin/sh -c /home/pi/TonyPi/Extend/ApriltagTrack.py
              root 8344 8343 2 17:42 ? 00:00:02 /usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py
              pi 8539 7159 0 17:43 pts/1 00:00:00 ps -ef
              pi@TonyPiPro:~ $
                {"trigger":"Pegar_Objeto.sh","command":"/home/pi/TonyPi/Extend/Pegar_Objeto.sh","ground":"background","voice":"Pegar Objeto","allowParams": "false"},
                  {"trigger":"ApriltagTrack.py","command":"/home/pi/TonyPi/Extend/Pegar_Objeto.sh","offCommand":"killall python3","ground":"background","voice":"Pegar Objeto","allo$
                    @Antonio-Francisco-S-Santos, please try this as your offCommand after you confirm it works manually.
                    kill -9 $(pgrep -f "/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py")
                      Executando direto do terminal aparece:
                      pi@TonyPiPro:~ $ kill -9 $(pgrep -f "/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py")
                      -bash: kill: (1683) - Opera▒▒o n▒o permitida
                      pi@TonyPiPro:~ $
                        @Antonio-Francisco-S-Santos, it's saying you don't have access, so you'll need to prefix the command with sudo, like this:
                        sudo kill -9 $(pgrep -f "/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py")
                        I see you're running the TRIGGERcmd background agent, which runs as root, so you don't need the sudo prefix when you add it to your commands.json.
                        You'll need to escape the command's quotes too, like this:
                        "offCommand": "kill -9 $(pgrep -f \"/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py\")"
                          Quando tento montar o comando ele só salvar dessa maneira:
                          {"trigger":"Sonar_barrier.py","command":"/home/pi/TonyPi/Extend/Caminhar.sh","offCommand":"kill -9 $(pgrep -f","ground":"background","voice":"Caminhar","allowParams": "false"}
                            @Antonio-Francisco-S-Santos, you need "allowParam": "true". Otherwise the agent will ignore the offCommand field.
                            Please try this entry.
                              "trigger": "Sonar Barrier",
                              "command": "/home/pi/TonyPi/Extend/Caminhar.sh",
                              "offCommand": "kill -9 $(pgrep -f \"/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py\")",
                              "ground": "foreground",
                              "voice": "Caminhar",
                              "voiceReply": "",
                              "allowParams": "true"
                              Olá, Com esse ultimo comando que você me mandou não faz nenhuma ação
                              {"trigger":"ApriltagTrack.py","command":"/home/pi/TonyPi/Extend/Pegar_Objeto.sh","offCommand":"kill -9 $(pgrep -f "/usr/bin/python3 /home/pi/TonyPi/Extend/ApriltagTrack.py")","ground":"foreground","voice":"Fechar Objeto","voiceReplay": "","allowParams": "true"}
                                @Russ Esse comando executa a função perfeitamente mas quando executo o comando de fechar nada acontece:
                                  @Antonio-Francisco-S-Santos, I don't know why it's not killing your python script. Maybe try killing your Pegar_Objeto.sh bash script instead.
                                  "offCommand": "kill -9 $(pgrep -f \"/bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh\")",
                                  How do you know it's not killing your script. Are you listing your processes with ps -ef after you run the command with "off" as the parameter?
                                    @Russ Olá Professor não consegue fechar os Script quando executado pelo TriggerCMD, se executar dentro do Debian no Terminal e abrir outro terminal com o comando Kill consegue fechar. o que pode ser professor?
                                      @Antonio-Francisco-S-Santos, Google translated that as, "... cannot close the Script when executed by TriggerCMD, if you run it inside Debian in Terminal and open another terminal with the Kill command you can close it."
                                      So I think you're saying this kill command only kills the Pegar_Objeto.sh script when you run the Pegar_Objeto.sh script manually, but not if you run it via TRIGGERcmd?
                                      kill -9 $(pgrep -f "/bin/bash /home/pi/TonyPi/Extend/Pegar_Objeto.sh")
                                      If you look at the pgrep command's help, you'll see that the -f parameter specifies the full process name, but I found that you can specify a partial process name.
                                      $ pgrep --help
                                      Usage:
                                       pgrep [options] <pattern>
                                      Options:
                                       -d, --delimiter <string>  specify output delimiter
                                       -l, --list-name           list PID and process name
                                       -a, --list-full           list PID and full command line
                                       -v, --inverse             negates the matching
                                       -w, --lightweight         list all TID
                                       -c, --count               count of matching processes
                                       -f, --full                use full process name to match
                                      So please try this instead:
                                      kill -9 $(pgrep -f Pegar_Objeto.sh)
                                      In your commands.json it would look like this:
                                      "offCommand": "kill -9 $(pgrep -f Pegar_Objeto.sh)",
                                        Executei esse comando manualmente mas não reve efeito:
                                        Coloquei tambem o endereço do código principal:
                                        kill -9 $(pgrep -f "/bin/bash /home/pi/TonyPi/Extend/ApriltagTrack.py")
                                        Mesmo assim não fechou o Script
                                          Agora colando dessa forma no terminal ele consegue fechar:
                                          kill -9 $(pgrep -f ApriltagTrack.py)
                                          Ainda não testei esse comando la no TriggerCMD
                                            @Antonio-Francisco-S-Santos Testei esse comando no TriggerCMD, funcionou perfeitamente só um Script que ficou dando esse erro:
