    Installation has failed
    1.6k
    • Igor GalletteI
      Igor Gallette
      Hi!
      Does anyone know how to resolve the error below?
      Check other topics, however the solutions were for 32bit windows.
      The windows I use is 10, 64bit.
      Thank you very much
      • tuicemenT
        tuicemen @Igor Gallette
        @igor-gallette did you check the properties of the installer prior to using to be sure it wasn't being blocked? Also did you try installing as Administrator?
        Igor GalletteI 1 Reply Last reply Reply Quote 0
        • Igor GalletteI
          Igor Gallette @tuicemen
          @tuicemen
          Yes, I tried but the error remains
          • tuicemenT
            @igor-gallette which version of Windows are you running?
              Russ @Igor Gallette
              @igor-gallette another idea - you could see if your antivirus software is blocking it. I've seen that before.
              • Igor GalletteI
                @tuicemen
                It is on 10.0.19043.
                However I did an update and now it shows this error below:
                2022-03-18 12:32:54> Program: Starting Squirrel Updater: --install .
                2022-03-18 12:32:54> Program: Starting install, writing to C:\Users\User\AppData\Local\SquirrelTemp
                2022-03-18 12:32:54> Program: About to install to: C:\Users\User\AppData\Local\TRIGGERcmdAgent
                2022-03-18 12:32:54> Program: Install path C:\Users\User\AppData\Local\TRIGGERcmdAgent already exists, burning it to the ground
                2022-03-18 12:32:55> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
                   em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
                   em System.IO.File.InternalDelete(String path, Boolean checkHost)
                   em System.IO.File.Delete(String path)
                   em Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file)
                   em Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1()
                   em System.Threading.Tasks.Task.InnerInvoke()
                   em System.Threading.Tasks.Task.Execute()
                --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada ---
                   em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
                   em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
                   em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext()
                   em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext()
                   em Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext()
                   em Squirrel.Utility.<LogIfThrows>d__42.MoveNext()
                2022-03-18 12:32:55> Unhandled exception: System.AggregateException: Um ou mais erros. ---> System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
                   em System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
                   em Squirrel.Update.Program.<Install>d__4.MoveNext()
                   --- Fim do rastreamento de pilha de exceções internas ---
                   em System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
                   em System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
                   em System.Threading.Tasks.Task.Wait()
                   em Squirrel.Update.Program.executeCommandLine(String[] args)
                   em Squirrel.Update.Program.main(String[] args)
                ---> (Exceção Interna N° 0) System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo.
                   em Squirrel.Update.Program.<Install>d__4.MoveNext()<---
                I have already accessed the page below and deleted all the files but the error remains.
                C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg```
                I've also tried restarting the computer and it didn't work.
                • Igor GalletteI
                  Igor Gallette @Russ
                  @russ
                  I have already disabled the firewall but the error persists.
                  But after updating windows, the "open setup log" is showing the error I sent in the previous message.
                    Russ @Igor Gallette
                    @igor-gallette , did you try temporarily disabling antivirus?
