Installation has failed
Hi!
Does anyone know how to resolve the error below?
Check other topics, however the solutions were for 32bit windows.
The windows I use is 10, 64bit.
Thank you very much
@igor-gallette did you check the properties of the installer prior to using to be sure it wasn't being blocked? Also did you try installing as Administrator?
Yes, I tried but the error remains
@igor-gallette which version of Windows are you running?
@igor-gallette another idea - you could see if your antivirus software is blocking it. I've seen that before.
It is on 10.0.19043.
However I did an update and now it shows this error below:2022-03-18 12:32:54> Program: Starting Squirrel Updater: --install . 2022-03-18 12:32:54> Program: Starting install, writing to C:\Users\User\AppData\Local\SquirrelTemp 2022-03-18 12:32:54> Program: About to install to: C:\Users\User\AppData\Local\TRIGGERcmdAgent 2022-03-18 12:32:54> Program: Install path C:\Users\User\AppData\Local\TRIGGERcmdAgent already exists, burning it to the ground 2022-03-18 12:32:55> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo. em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) em System.IO.File.InternalDelete(String path, Boolean checkHost) em System.IO.File.Delete(String path) em Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file) em Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1() em System.Threading.Tasks.Task.InnerInvoke() em System.Threading.Tasks.Task.Execute() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<LogIfThrows>d__42.MoveNext() 2022-03-18 12:32:55> Unhandled exception: System.AggregateException: Um ou mais erros. ---> System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo. em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) em System.IO.File.InternalDelete(String path, Boolean checkHost) em System.IO.File.Delete(String path) em Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file) em Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1() em System.Threading.Tasks.Task.InnerInvoke() em System.Threading.Tasks.Task.Execute() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<LogIfThrows>d__42.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) em Squirrel.Update.Program.<Install>d__4.MoveNext() --- Fim do rastreamento de pilha de exceções internas --- em System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) em System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) em System.Threading.Tasks.Task.Wait() em Squirrel.Update.Program.executeCommandLine(String[] args) em Squirrel.Update.Program.main(String[] args) ---> (Exceção Interna N° 0) System.IO.IOException: O processo não pode acessar o arquivo 'C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg' porque ele está sendo usado por outro processo. em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) em System.IO.File.InternalDelete(String path, Boolean checkHost) em System.IO.File.Delete(String path) em Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file) em Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1() em System.Threading.Tasks.Task.InnerInvoke() em System.Threading.Tasks.Task.Execute() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<DeleteDirectory>d__19.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em Squirrel.Utility.<LogIfThrows>d__42.MoveNext() --- Fim do rastreamento de pilha do local anterior onde a exceção foi gerada --- em System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) em System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) em System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) em Squirrel.Update.Program.<Install>d__4.MoveNext()<---I have already accessed the page below and deleted all the files but the error remains.
C:\Users\User\AppData\Local\TRIGGERcmdAgent\packages\TRIGGERcmdAgent-1.0.25-full.nupkg```I've also tried restarting the computer and it didn't work.
I have already disabled the firewall but the error persists.
But after updating windows, the "open setup log" is showing the error I sent in the previous message.
@igor-gallette , did you try temporarily disabling antivirus?
