    Questions on TCMD tool and usage?
    12 Posts 2 Posters 2.5k Views
    • tuicemenT Offline
      tuicemen @tuicemen
      UpDate: still no luck 😞
      I also tried sudo ./tcmd -c -t Panic
      and get "No trigger specified. Use --help or -h for help."
      Running as Root makes no difference
        Russ @tuicemen
        @tuicemen, it doesn't have to be in any particular folder.
        You're missing the computer name in your commands. Here's an example of it working:
        tcmd -c russfam -t calculator
        {"message":"Trigger sent."}
        You can also run this to use --list to show a list of tcmd commands - one for each of your TRIGGERcmd commands on each of your computers.
        tcmd -list
        0 tcmd --computer "bedroompi" --trigger "apt update"
        1 tcmd --computer "bedroompi" --trigger "Bedroom" --params "(your parameters)"
        Or use --help to show help:
        C:\Users\russe\.TRIGGERcmdData>tcmd -h
        NAME:
            tcmd - Run commands on computers in your TRIGGERcmd account
          USAGE:
            tcmd [options]
          OPTIONS:
            --trigger value, -t value   Trigger name of the command you want to run
            --computer value, -c value  Name of the computer (leave blank for your default computer)
            --params value, -p value    Any parameters you want to add to the remote command
            --list, -l                  List your commands
            --help, -h                  show help
            --version, -v               print the version
        FYI, it logs in using the ~/.TRIGGERcmdData/token.tkn or C:\Users\(user)\.TRIGGERcmdData\token.tkn file depending on the OS. That token.tkn file gets written when you install the TRIGGERcmd agent.
        • tuicemenT Offline
          tuicemen @Russ
          @russ directions state -c option can be blank if running from default which I am I'll try adding computer name
          • tuicemenT Offline
            tuicemen @tuicemen
            Yep that did it! thanks
              Russ @tuicemen
              @tuicemen said in Questions on TMCD tool and usage?:
              You're right, that should work. Thanks for pointing that out. I need to fix that.
              EDIT: Fixed - now if you don't specify the computer it will run on your default computer.
              tuicemenT 2 Replies Last reply Reply Quote 0
              • tuicemenT Offline
                tuicemen @Russ
                @russ, thanks I'll update the tool.
                • tuicemenT Offline
                  tuicemen @Russ
                  @russ I updated the tool, option -v states: tcmd version 1.0.5
                  Can't remember what it was previously but I still have to input the computer name.
                  Maybe the issue is only for the tcmd-linux-arm file.
                    Russ @tuicemen
                    @tuicemen, I actually fixed it on the server side in this case. I found that it even worked on version 1.0.3
                    tcmd  -t calculator
                    tcmd -v
                    tcmd version 1.0.3
                    I upgraded to 1.0.5 and it still works:
                    tcmd -v
                    tcmd version 1.0.5
                    tcmd  -t calculator
                    • tuicemenT Offline
                      tuicemen @Russ
                      @russ yep your right it works, guess my fat fingers got in the way.
                      Sorry about that.
                        Russ @tuicemen
                        @tuicemen, nice, no problem. I'm glad it works.
                        Isn't that a nice way to trigger your command from a command? I think it's easier than using curl.
                        • tuicemenT Offline
                          tuicemen @Russ
                          @russ Ya it is so simple to use. I like the list option for showing trigger names. My memory isn't what it use to be and my spelling never was the greatest!
