    Questions on TCMD tool and usage?
    641
    • tuicemenT
      tuicemen
      So I just found this cool tool and have several ideas for its usage.
      I've downloaded it and attempted to use it from my Raspi where TRIGGERCMD is install but I get the error {"error":"Computer not found."}
      So I'm doing something wrong.
      Does the file need to be in a specific folder? I have it in my /home/pi/scripts folder
      does it have to be run from inside a script? I'm testing just from command line using sudo ./tcmd -t Panic
      Panic is the name of my TRIGGERcmd trigger
      Does it need to be run from root in this case?
      • tuicemenT
        tuicemen @tuicemen
        UpDate: still no luck 😞
        I also tried sudo ./tcmd -c -t Panic
        and get "No trigger specified. Use --help or -h for help."
        Running as Root makes no difference
          Russ @tuicemen
          @tuicemen, it doesn't have to be in any particular folder.
          You're missing the computer name in your commands. Here's an example of it working:
          tcmd -c russfam -t calculator
          {"message":"Trigger sent."}
          You can also run this to use --list to show a list of tcmd commands - one for each of your TRIGGERcmd commands on each of your computers.
          tcmd -list
          0 tcmd --computer "bedroompi" --trigger "apt update"
          1 tcmd --computer "bedroompi" --trigger "Bedroom" --params "(your parameters)"
          Or use --help to show help:
          C:\Users\russe\.TRIGGERcmdData>tcmd -h
          NAME:
              tcmd - Run commands on computers in your TRIGGERcmd account
            USAGE:
              tcmd [options]
            OPTIONS:
              --trigger value, -t value   Trigger name of the command you want to run
              --computer value, -c value  Name of the computer (leave blank for your default computer)
              --params value, -p value    Any parameters you want to add to the remote command
              --list, -l                  List your commands
              --help, -h                  show help
              --version, -v               print the version
          FYI, it logs in using the ~/.TRIGGERcmdData/token.tkn or C:\Users\(user)\.TRIGGERcmdData\token.tkn file depending on the OS. That token.tkn file gets written when you install the TRIGGERcmd agent.
          • tuicemenT
            tuicemen @Russ
            @russ directions state -c option can be blank if running from default which I am I'll try adding computer name
            • tuicemenT
              tuicemen @tuicemen
              Yep that did it! thanks
                Russ @tuicemen
                @tuicemen said in Questions on TMCD tool and usage?:
                You're right, that should work. Thanks for pointing that out. I need to fix that.
                EDIT: Fixed - now if you don't specify the computer it will run on your default computer.
                tuicemenT 2 Replies Last reply Reply Quote 0
                • tuicemenT
                  tuicemen @Russ
                  @russ, thanks I'll update the tool.
                  • tuicemenT
                    tuicemen @Russ
                    @russ I updated the tool, option -v states: tcmd version 1.0.5
                    Can't remember what it was previously but I still have to input the computer name.
                    Maybe the issue is only for the tcmd-linux-arm file.
                      Russ @tuicemen
                      @tuicemen, I actually fixed it on the server side in this case. I found that it even worked on version 1.0.3
                      tcmd  -t calculator
                      tcmd -v
                      tcmd version 1.0.3
                      I upgraded to 1.0.5 and it still works:
                      tcmd -v
                      tcmd version 1.0.5
                      tcmd  -t calculator
                      • tuicemenT
                        tuicemen @Russ
                        @russ yep your right it works, guess my fat fingers got in the way.
                        Sorry about that.
                          Russ @tuicemen
                          @tuicemen, nice, no problem. I'm glad it works.
                          Isn't that a nice way to trigger your command from a command? I think it's easier than using curl.
                          • tuicemenT
                            tuicemen @Russ
                            @russ Ya it is so simple to use. I like the list option for showing trigger names. My memory isn't what it use to be and my spelling never was the greatest!
