    token
    15 Posts 3 Posters 3.5k Views 1 Watching
    • Steve GardinierS Offline
      Steve Gardinier
      my pc
      \sorry
        Russ @Steve Gardinier
        @Steve-Gardinier, so you got it figured out?
          Steve Gardinier
          NO WHEN I PASTEeyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6IjVmZjY1ZWE3MzcyMjg3MDAxOTI0MmE1YyIsImlhdCI6MTYyOTMzNTgzMn0.rQGmwz1NNnauc9vJk6bPsg3GZByNgtkStCqqo8Aweyg i ONLY GET 5 DIGIT THEN IF WONT LET ME TYPE THE REST OF IT.
          IT WORK HERE
          TWO DIFFERT PC WITH NO NAMES DOSE THE SAME THING
          THE OTHER IS A PRO
          Steve GardinierS 1 Reply Last reply Reply Quote 0
            Steve Gardinier @Steve Gardinier
            @Steve-Gardinier eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6IjVmZjY1ZWE3MzcyMjg3MDAxOTI0MmE1YyIsImlhdCI6MTYyOTQyMDkzMH0.iWel_IrB_8oDD0qSVVuju_OWIlHS5LC24z79mtk6xU0
            I PASTED IT HERE and drag it to pair code*
            eyjhb
            this is all it gives
              Steve Gardinier @Russ
              @Russ I have no clue but i miss my automated house can you get on my cpu and help
                @Steve-Gardinier I think you're trying to copy the long token string into the pair code field. There's no need to do that.
                Use the token to login the agent on your PC. You probably have no need right now for the tcmd utility, so forget about the "Pair" option.
                  @Russ I can get trigger in the back ground
                    @Steve-Gardinier I said can when i cant
                    can you help me get trigger in my back ground i didn't understand or it wont work
                        @Steve-Gardinier, you should not paste your token into that Pair Code field. It's not meant for that.
                        You should install the TRIGGERcmd Agent on your computer, then paste your token into this screen:
