    token
    Instructions
    862
    • Steve GardinierS
      Steve Gardinier
      lost the ability to copy and paste or drag the token only 5 or 6 digits will work
        Russ @Steve Gardinier
        @Steve-Gardinier, please tell me more - are you using your phone or a browser on your PC?
        You can find your token in your profile page and on the instructions page.
        Steve GardinierS 1 Reply Last reply Reply Quote 0
        • Steve GardinierS
          Steve Gardinier
          when i copy ctrl c then ctrl v it gives me eyJhb
          thats it
          • Steve GardinierS
            Steve Gardinier
            I use the profile page too same result
            • Steve GardinierS
              Steve Gardinier
              i have 22 x10 lights 5 stereo with x10 that dont work any more
              • Steve GardinierS
                Steve Gardinier
                my pc
                \sorry
                  @Steve-Gardinier, so you got it figured out?
                  • Steve GardinierS
                    Steve Gardinier
                    NO WHEN I PASTEeyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6IjVmZjY1ZWE3MzcyMjg3MDAxOTI0MmE1YyIsImlhdCI6MTYyOTMzNTgzMn0.rQGmwz1NNnauc9vJk6bPsg3GZByNgtkStCqqo8Aweyg i ONLY GET 5 DIGIT THEN IF WONT LET ME TYPE THE REST OF IT.
                    IT WORK HERE
                    TWO DIFFERT PC WITH NO NAMES DOSE THE SAME THING
                    THE OTHER IS A PRO
                    • Steve GardinierS
                      Steve Gardinier @Steve Gardinier
                      @Steve-Gardinier eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpZCI6IjVmZjY1ZWE3MzcyMjg3MDAxOTI0MmE1YyIsImlhdCI6MTYyOTQyMDkzMH0.iWel_IrB_8oDD0qSVVuju_OWIlHS5LC24z79mtk6xU0
                      I PASTED IT HERE and drag it to pair code*
                      eyjhb
                      this is all it gives
                      • Steve GardinierS
                        Steve Gardinier @Russ
                        @Russ I have no clue but i miss my automated house can you get on my cpu and help
                          @Steve-Gardinier I think you're trying to copy the long token string into the pair code field. There's no need to do that.
                          Use the token to login the agent on your PC. You probably have no need right now for the tcmd utility, so forget about the "Pair" option.
                          • Steve GardinierS
                            @Russ I can get trigger in the back ground
                            • Steve GardinierS
                              @Steve-Gardinier I said can when i cant
                              can you help me get trigger in my back ground i didn't understand or it wont work
                              • Steve GardinierS
                                  @Steve-Gardinier, you should not paste your token into that Pair Code field. It's not meant for that.
                                  You should install the TRIGGERcmd Agent on your computer, then paste your token into this screen:
