    Turn Computer Monitors Off
    Linux
    6.8k
    • T
      Tony Bineyard
      For Linux:
      {"trigger":"Turn Monitors Off","command":"xset dpms force off","ground":"foreground","voice":"monitors off"},
        Russ @Tony Bineyard
        Thanks @tony-bineyard. I added this to the list of examples that show up in the agent GUI.
        • H
          heyfrank @Russ
          @russ @Tony-Bineyard How does this work if you sit down at your computer 10 minutes later, do the monitors turn back on?
            Russ @heyfrank
            @heyfrank, I don't know. I don't use this because I don't use a Linux computer for my desktop.
            • S
              shakepayshaker
              If you want to turn monitors off with windows (jiggle mouse turns them back on)
              powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
              exit
              Jean silvaJ 1 Reply Last reply Reply Quote 2
              • Jean silvaJ
                Jean silva @shakepayshaker
                @shakepayshaker please send how to use the command to turn the monitor back on by Windows as well
                RussR 1 Reply Last reply Reply Quote -1
                  Russ @Jean silva
                  @Jean-silva and @shakepayshaker, I replied in this post in the Windows section.
                  • Jogador Extremo liveJ
                    I have two monitor, is there a way to turn off just my second monitor?
                    • O
                      Olivotec
                      @Jogador-Extremo-live said in Turn Computer Monitors Off:
                      So this is basically what I need, did you manage to do this?
                      I want to play games on my TV which is one of 3 monitors I have. And i want to turn off both monitors to have only the TV i'm using to game
