    Autohotkey script for Play, Pause, Volume Up/Down, Next/Previous
    34 Posts 10 Posters 38.6k Views 1 Watching
      Another way to play/pause is to simulate pressing the space bar with a command like this:
      wscript c:\scripts\space.vbs
      The contents of c:\scripts\space.vbs would look like this:
      Dim Wsh
      Wsh.SendKeys "{ }"
      • ChabeticoC Offline
        Chabetico
        So, I tell alexa to execute this command but open cmd and say that she couldn't find such a directory. I tried to do without the "start" at the beginning but nothing happens. If you can help me I would appreciate it, I am new to this branch of TriggerCMD, I started yesterday to tell the truth. sorry about my English
        ChabeticoC 1 Reply Last reply Reply Quote 0
          Chabetico @Chabetico
          @Chabetico I tested it and triggercmd does not execute the command, I sent him to write a letter through AHK, but nothing came out
            Russ @Chabetico
            @Chabetico, please show me the command you're having TRIGGERcmd run.
            You might need to specify the full path of the AutoHotkey.exe and your script, so your command would look like this:
            "C:\Program Files\AutoHotkey\AutoHotkey.exe" "C:\autohotkeyscripts\yourscript.ahk"
            ChabeticoC L 2 Replies Last reply Reply Quote 0
              Chabetico @Russ
                • L Offline
                  Laaderlappen @Russ
                  @Russ Hey, awesome skill to use with Alexa, I set it up with routines and it works like a charm!
                  I can manage to pause and play YouTube and Netflix without any issues but I run Plex Media Player from my PC as well and it can't pause or play Plex at all, do you know how can I achieve that? It's the only thing that I'm missing.
                  It's like it is not recognizing the play and pause command.
                  I wanted to try with space but don't know how to set it up.
                    Russ @Laaderlappen
                    @Laaderlappen, I use Plex alot myself. I just tested space and it was able to play/pause on my PC. There are a few ways, but this is how I did it.
                    This is my command:
                    wscript d:\tools\space.vbs
                    These are the contents of my d:\tools\space.vbs file:
                    Dim Wsh
                    Wsh.SendKeys "{ }"
                    • L Offline
                      Laaderlappen @Russ
                      @Russ Thanks for the quick reply!
                      Unfortunately it doesn't work.
                      It doesn't even pauses YouTube or Netflix.
                      I use the Plex Media Player app.
                      The regular pause command is working with YouTube and Netflix in the browser but the Plex Media Player app that has its own .exe doesn't recognize anything.
                        Russ @Laaderlappen
                        @Laaderlappen, I see. I was using Plex in the browser yesterday, but I tried Plex for Windows today and it worked for me in that too.
                        I tried Plex for Windows version 1.11.0.1215-1d8c460c and the latest from this page which is currently 1.31.1.2262-74fdc6b7:
                        https://www.plex.tv/media-server-downloads/#plex-app
                        Both worked for me.
                        Please confirm the Ground field is set to foreground.
                        • L Offline
                          Laaderlappen @Russ
                          @Russ Sorry for the delay replying! Though week!
                          I ended up installing my Mi Box in my bedroom, I needed the remote control haha.
                          It didn't work, tried everything and nothing.
                          Thanks for the quick replies tho!
                          • Sori _S Offline
                            Sori _
                            @Russ I really liked your skill, but I wanted to know how I can, go back and continue videos on youtube/netflix with alexa's voice command, because when I use the command a message appears on my PC "windows cannot find C://autohotkeyscripts//media.ahh. make sure the name was typed correctly and try again.
                            PS: I'm very beginner so could you explain to me how to use the codes that are at the top of the page?
                              Russ @Sori _
                              @Sori-_, you'll need to:
                              • Install AutoHotkey
                              • Create a autohotkeyscripts folder on your 😄 drive
                              • Create the media.ahk script in that folder.
                              • Create commands like these:
                              "C:\Program Files\AutoHotkey\AutoHotkey.exe" "C:\autohotkeyscripts\media.ahk" mute
                              "C:\Program Files\AutoHotkey\AutoHotkey.exe" "C:\autohotkeyscripts\media.ahk" play
                              Sori _S William Santiago Ortiz TrejosW 3 Replies Last reply Reply Quote 0
                              • Sori _S Offline
                                Sori _ @Russ
                                • Sori _S Offline
                                  Sori _ @Russ
                                  @Russ Thanks man, you made a great explanation and program kkkkkk,
                                  thanks for help.
                                  • William Santiago Ortiz TrejosW Offline
                                    William Santiago Ortiz Trejos @Russ
                                    @Russ Hi, I have been trying to trigger the media commands the same way that you explain. But I have an issue when I run "media.ahk". My computer always asks me how do I want to open that file. This is a screenshot of TriggerCMD. 0a8d3e11-891b-4205-8216-608947fbd845-image.png As you see in the previous image that's how I have the "next song" command.
                                    And in the following screenshot, you will find the message that I receive.
                                    Thanks for your help
                                      Russ @William Santiago Ortiz Trejos
                                      @William-Santiago-Ortiz-Trejos, for some reason your files with a .ahk extension aren't associated with AutoHotkey. That's supposed to happen when you install it, but maybe an antivirus program blocked it?
                                      To fix it you could try running the batch file in this article from your C:\Program Files\AutoHotkey folder:
                                      https://www.autohotkey.com/board/topic/13627-no-ahk-file-association/
