    What's the difference between background and foreground commands?
    23 Posts 8 Posters 48.7k Views 1 Watching
    • Sergio GryciukS Offline
      Sergio Gryciuk
      hello could you give an example command to turn off my Imac and tried this "shutdown / s / t 2" in foreground and it doesn't work.
        Russ @Sergio Gryciuk
        @Sergio-Gryciuk, I actually recently added Shutdown and a few other Mac examples to GUI Editor's example list. Here it is too:
        osascript -e 'tell app "System Events" to shut down'
          Sergio Gryciuk
          Muchas gracias Russ, eres un genio el comando de apagar mi mac funciono perfectamente.
            Awesome @Sergio-Gryciuk, you're welcome.
            • K Offline
              Kingnabis
              I have a question because i cant difference or i dont see the difference about it.
              i have two comands, foreground and background one. Both make same (on windows 10) i have a shutdown /s /t 10 and both make same. Maybe this is only for Mac os users usefull?
              But basically i cant run apps (native apps), like notepad.exe (foreground of course, but any of two works for me)
              I tell on spanish Alexa, open (or run, or nothing, only /notepad/ or /noutpad/ both spechs works) notepad. And it sounds like the comand its suscesfully done but nothnig appears on screen.
              Whats my issue?
                Russ @Kingnabis
                @Kingnabis, you're saying you can not run notepad, correct?
                I recommend that you try using the TRIGGERcmd Smart Home Alexa skill. It recognizes your voice commands better because it has a list of what you might say ahead of time, so Alexa only has to match up what you say with something in that list.
                Is your notepad command setup like this?
                When you click the View Runs button,
                do you get a Command ran entry in your list?
                • K Offline
                  Kingnabis
                  Yes, mine was like yours but i was jumping the COMAND part. I need to add START previously to notepad... I udapted like this and it works. I have to write it on cmd, if works there works from the skill. asdge.PNG
                  • K Offline
                    Kingnabis
                    • adriangcamachoA Offline
                      adriangcamacho
                      Hi, any solution to run background commands in mac os?
                        Russ @adriangcamacho
                        @Adrián-González-Camacho, not yet. I didn't think many Mac users would want to use it. Do you want this feature so you can run commands while you're not logged on? Just curious what your use-case is.
                        adriangcamachoA 1 Reply Last reply Reply Quote 0
                          adriangcamacho @Russ
                          @Russ I want to use my mac as a server and launch home automation commands
                            @adriangcamacho, I see. I assume you don't want to leave it logged in?
                            I'll have to research again how to create services that startup at boot time on a Mac.
                            adriangcamachoA 1 Reply Last reply Reply Quote 1
                              @Russ Yep, thank you a lot for your time.
                              If you need some help i think i could help you i'm backend developer.
                              • TuneyLunesT Offline
                                TuneyLunes
                                I'd also like to use my mac as an automation server and it would be easier to not have to be logged in permanently. Thanks @Russ !
                                  Russ @TuneyLunes
                                  @TuneyLunes, I haven't built this into the Mac agent yet, so for now you can use this method to setup the background agent on a Mac.
                                  • Alê 滝口A Offline
                                    Alê 滝口 @Russ
                                    @Russ Could you give me an example of a command to run a script?
                                      Russ @Alê 滝口
                                      @Alê-滝口, if the computer is running Mac or Linux, the command could be:
                                      ~/yourscript.sh
                                      That assumes you've created a script in your home directory called yourscript.sh.
                                      If the computer is running Windows, the command could be:
                                      c:\scripts\yourscript.bat
                                      That assumes you created a c:\scripts folder, and put yourscript.bat in it.
                                      Alê 滝口A 1 Reply Last reply Reply Quote 0
                                      • Alê 滝口A Offline
                                        Alê 滝口 @Russ
                                        @Russ thank you !!!
