    Where are the actual installation instructions?
    4 Posts 2 Posters 1.1k Views 1 Watching
    • Ron ParkerR Offline
      Ron Parker
      I sort of fumbled around and got the TriggerCMD agent installed, but service status still says "failed". I found a command line command to access the agent, but it asks for a "token", and I realized I haven't a clue as to how to configure this thing or access it.
      I clicked in "Installation" forum, but I can only find a ton of posts about different types of installs. I am installing on Centos 7 system. Can someone help me get past this "failed" problem and point me to clear install and config instructions?
      Thanks!
      [root@ip TriggerCMD]# service triggercmdagent start
      Redirecting to /bin/systemctl start triggercmdagent.service
      [root@ip TriggerCMD]# service triggercmdagent status
      Redirecting to /bin/systemctl status triggercmdagent.service
      Loaded: loaded (/etc/systemd/system/triggercmdagent.service; enabled; vendor preset: disabled)
      Active: failed (Result: start-limit) since Sat 2021-02-27 20:59:34 PST; 17s ago
      Process: 2902 ExecStart=/usr/bin/env node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /root/.TRIGGERcmdData (code=exited, status=0/SUCCESS)
      Main PID: 2902 (code=exited, status=0/SUCCESS)
      Feb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: triggercmdagent.service holdoff time ove...t.Feb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: Stopped TRIGGERcmd Agent.
      Feb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: start request repeated too quickly for t...ceFeb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: Failed to start TRIGGERcmd Agent.
      Feb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: Unit triggercmdagent.service entered fai...e.Feb 27 20:59:34 ip.us-west-2.compute.internal systemd[1]: triggercmdagent.service failed.
      Hint: Some lines were ellipsized, use -l to show in full.
      [root@ip TriggerCMD]# node /usr/share/triggercmdagent/resources/app/src/agent.js --console
      Daemon install: false
      prompt: token:
        Ron Parker
        OK, I have made a little progress. I found my token, entered it from the GUI, purchased a subscription, and now I can see my computer at: https://www.triggercmd.com/user/computer/list
        However, when trying to create a zap using TriggerCMD, still getting "The trigger could not be sent to TRIGGERcmd" error. It's probably because I'm missing something in the instructions -- because I can't find them!!!
        TriggerCMD your computers - 2021-02-28_0-45-25.jpg TriggerCMD - The trigger could not be sent to app - 2021-02-27_20-22-32.jpg
          Ron Parker
          Well, without instructions, I figured it out.
          First, I was getting the "trigger could not be sent" error because I failed to select a trigger in the first place.
          Second, I needed to get to the gui command editor, which is this teeny-tiny red box at the top right hand corner of my screen. But, I found it
          Added a command with parameters. Tested it. It works.
          We are rocking now.
            Russ @Ron Parker
            @Ron-Parker, I'm glad you figured it out, but you're right, I see I have Ubuntu Linux instructions for the .deb file install, but none for installing the .rpm on Redhat/Centos/Fedora type Linux OS's. I'll correct that soon. Thank you for pointing this out.
            All I found were these instructions for upgrading it.
            I think I should have an index page that lists each OS with links to installation instructions, similar to the trigger methods page to make them easy to find.
