    50 Posts 8 Posters 23.1k Views 2 Watching
      @TheConfax, honestly I forgot about it, but I'd like to solve it if I can.
      I wonder if the problem is specific to certain non-english versions of Windows 10. Are you running an Italian version of Windows 10?
      I'm confident I can solve it if I can reproduce the problem. I'd like to create a virtual machine running Windows 10 with the Italian version (if that's what you're running). I tried installing an additional language on my Windows, but that didn't show me the problem.
      Right now I'm downloading an Italian version of Windows 10 ISO using the media creation tool I downloaded from here:
      https://www.microsoft.com/it-it/software-download/windows10
        @Russ Yes, I'm running Win10 Home in Italian, probably the Brazilian guy had one in Portuguese... could be that, let us know πŸ˜‰
          @TheConfax, bad news. It worked fine for me. I installed the TRIGGERcmd agent and rebooted my Italian version of Windows 10 and it automatically started up.
            @Russ To be honest is not a constant thing, without the fix it starts like 1 out of 10 attempts, with the .bat fix it starts like 19 out of 20 attempts.
            Try rebooting some times, if unsuccesful in breaking it, try shutting down and powering on the virtual machine some times, both with and without fast startup enabled.
              @TheConfax, I tried rebooting the VM many times and I have not seen the problem.
              I did an experiment though - I disconnected the VM from the Internet, then quit and re-launched the TRIGGERcmd agent, and I found that it automatically quit because it couldn't connect to the server.
              I wonder if that's what's happening to you. Is it possible your TRIGGERcmd agent is launching before your computer is connected to the Internet during boot?
                @Russ Yes, it is very much possible, because my Wi-Fi card connects only after user login.
                In my .bat fix i included a 30 second delay, that could explain why even that sometimes is not working.
                You could try implementing a little loop at boot checking for network more than one time and it should be fixed ^^
                  @TheConfax, ok, yea I think I can fix this.
                    Thank you @Russ !
                    Let me know when it's done and thanks again for the very useful application!
                      @TheConfax, I fixed it. Please update your agent. Now it will retry every 10 seconds if there's no Internet. I tested by rebooting the VM while it was disconnected from the network, then I enabled the network a while after the agent started. It connected within 10 seconds.
                        @Russ Thanks for the fix! I will test it during the next days and I'll let you know if it hangs again, hopefully should be ok.
                        • P Offline
                          Paulo Filho
                          I'm from Brazil and I have the same problem, the fix doesn't work here. If anyone knows the fix about the .exe (.bat file in the background doesnt appearing the black box of CMD) help me please.
                            [[global:former-user]] @Paulo Filho
                            @Paulo-Filho Try uninstalling and removing the .bat fix, then reinstall the latest version and make sure it is in the automatic run folder.
                            It is your PC connected to the internet at launch?
                            @Russ For me it never broke up to now πŸ‘πŸ»
                            • P Offline
                              Paulo Filho @Guest
                              @TheConfax Yes, its connected at launch. The .bat fix finally worked here, now how i can transform in a .exe to not show the cmd in the intro?
                                @Paulo-Filho You can use any exe-bat converter. But Russ updated the software, now it should work even without the bat fix
                                • Mark HollisM Offline
                                  Mark Hollis
                                  @Russ i have a startup problem on windows 10, if i set triggercmd to launch as administrator, it won't launch at window startup, you know why? thanks for help
                                    Russ @Mark Hollis
                                    @Mark-Hollis, how are you trying to run the agent as administrator during startup?
                                    Are you using this checkbox on the shortcut? If so, how are you running that during startup?
                                    Mark HollisM 1 Reply Last reply Reply Quote 1
                                      Mark Hollis @Russ
                                      @Russ yes exactly
                                      the link to exe is in this folder C:\Users\Carmelo\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\TRIGGERcmd
                                      without checking run as administrator, triggercmd start correctly at boot
                                        Russ @Mark Hollis
                                        @Mark-Hollis, I actually included a feature to run the agent in background mode in the context of a Windows service that starts up on boot. It runs your background commands elevated.
                                        You install it using this "Install Background Service"
                                        Set your commands as background commands like this:
                                        The normal forground agent starts up when you login, and it runs commands non-elevated.
                                        If you still want to use a shortcut with that "Run this program as an administrator" checkbox checked, you'll need to disable UAC, and you'll need to check the box on the TRIGGERcmd Agent shortcut in this folder:
                                        C:\Users\Carmelo\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                        This article shows how to quickly open that folder with shell:startup.
                                          Mark Hollis @Russ
                                          @Russ i already have uac disable, and ticked administrator to that shortcut in that folder, but this way don't start when windows 10 start
                                          • trinibT Offline
                                            trinib
                                            I have this a same issue on windows 10 when no internet at startup. And even with the feature @Russ added - check for internet connection every 10 second is useless for when no internet, service never start properly even after connecting to internet. Will need to force close service and run again with internet on.
                                            ##### But easy work around using task scheduler.πŸ˜‰πŸ‘‡
                                            1. Open Task Scheduler
                                            • Start Menu β†’ Task Scheduler
                                            1. New Task
                                            • Action: Create Task…
                                            • Name: TriggerCMD Agent
                                            • Security: Run only when user is logged on
                                            • (Optional: check β€œRun with highest privileges”)
                                            1. Trigger
                                            • Click Triggers β†’ New…
                                            • Begin the task: At log on
                                            • Settings: Specific user or Any user β†’ OK
                                            1. Action
                                            Actions β†’ New…
                                            • Action: Start a program
                                            • Program/script:
                                              C:\Users\Admin\AppData\Local\triggercmdagent\TRIGGERcmdAgent.exe
                                            • OK
                                            1. Condition
                                            • Go to Conditions tab
                                            • Check Start only if the following network connection is available
                                            • Select Any connection
                                            • OK
                                            1. Finish
                                            Click OK to save
                                            (Enter your password if prompted)
                                            LOVE THIS SOFTWARE . Hope it never dies πŸ™. paying for full features😎
                                            With your input, this post could be even better πŸ’—
