@Russ it works, thank you.
P
Offline
RE: Sleep command
@Russ , yes the command works in the website (Trigger) and in GUI, but dont work with Alexa, I said the same that you, seconds after, she accept the command but nothing happens.
Sleep command
I dont get how to use the sleep command in TriggerCMD, im using: " rundll32.exe powrprof.dll,SetSuspendState 0,1,0 ", but doesnt work with Alexa unless I click on play in the command in TriggerCMD GUI.
RE: TRIGGERcmd not starting at boot
@TheConfax Yes, its connected at launch. The .bat fix finally worked here, now how i can transform in a .exe to not show the cmd in the intro?
I'm from Brazil and I have the same problem, the fix doesn't work here. If anyone knows the fix about the .exe (.bat file in the background doesnt appearing the black box of CMD) help me please.
