    closing apps
    1.9k
    • nalkoN
      nalko
      I found the commands to run apps, but i want to be able to close them to.
      • Furkan CevikF
        Furkan Cevik
        Lets say we want to close Whatsapp. You go to Task Manager and check out the Details.
        There we see that Whatsapps programm is called "Whatsapp.exe".
        To kill or to close it, you run this:
        taskkill /IM "whatsapp.exe" /F
        You can do this with any other program, just switch out the .exe name.
        • nalkoN
          nalko
          thank you very much
          • L
            lcancio
            hello everyone. i cant get through this with the calc.exe fil in order to close the application. any guess on this? thank you
              Russ @lcancio
              @lcancio, for some reason you run Calculator with "calc" but the .exe is calculator.exe so you have to close it using the calculator.exe like this:
              L 1 Reply Last reply Reply Quote 1
              • L
                lcancio @Russ
                @Russ said in closing apps:
                Uff. thank you so much for the advise!!
                it works. Appreciate it.
                1 Reply Last reply Reply Quote 2
