    Como usar o Nircmd?
    Example Commands
    3.3k
    • Ricardo PereiraR
      Ricardo Pereira
      Sempre que dou comando no trigger ele abre o prompt.
      Como fazer?
        Russ @Ricardo Pereira
        @Ricardo-Pereira, first, download the nircmd.exe file from here:
        https://www.nirsoft.net/utils/nircmd.html
        Copy the nircmd.exe file to c:\windows or some other folder that your PATH environment variable points to. That way you can make your commands like this:
        nircmd screensaver
        Or, if you put nircmd.exe in a folder like c:\tools, then make your commands like this:
        c:\tools\nircmd screensaver
        There are a lot of examples at that URL above, and the NirCmd.chm help file that nircmd comes with has even more.
        Fatima NuraF 1 Reply Last reply Reply Quote 0
        • Fatima NuraF
          Fatima Nura @Russ
          @Russ said in Como usar o Nircmd?:
          nircmd screensaver
          e em outros horĂ¡rios jogue em https://sweet-bonanza.com.br/1win-cassino
          Thank you
          • XanderX
            Xander @Fatima Nura
            @Russ Don't forget that if you run Nircmd without any parameters at all, it provides a button to copy it to c:\windows. It must be run with Admin privileges (Run box ... ctrl+shift+enter) though.
              Russ @Xander
              @Xander, good point.
