    Open Specific Netflix Movie with Alexa
    40 Posts 8 Posters 22.7k Views 1 Watching
    • Felipe GuedesF Offline
      Felipe Guedes
      Hello guys,
      I'm from Brazil, and i need to know how to configure or talk to alexa to start the command?
      Can you help me?
      Other wise, in chrome driver, you know how to configure full screen when start the movie or serie?
      RussR Felipe GuedesF 2 Replies Last reply Reply Quote 0
        Russ @Felipe Guedes
        @Felipe-Guedes, I'm glad you asked because I forgot to add the Brazil link to this page.
        Have you seen this video yet? It shows the newer Smart Home version of the skill, which I prefer personally because it recognizes your words better.
        If you want to use the original skill, you should be able to say, "Alexa, abrir Execute Comando" to get started, or use this link.
        Also, to answer your other question, no I don't know how to make it go full screen. If you figure that out, please post the solution.
          Felipe Guedes
          @Russ sorry i'm very dummy, i don't know how to execute with parameters.
          I try this several times, but the Execute comando dont recognize my pc.
          I try to say: "Alexa, abrir Execute Comando", thats perfect, after that, when i say: "Execute automação(That is name to my command) no PC(voice name) com parametro boss baby, doesn't work, Alexa say: Eu não encontrei o dispositivo PC.
          Can you create a video with a exemple executing something with parameters, and configuration.
            Russ @Felipe Guedes
            @Felipe-Guedes, before you try to use Alexa, you should make sure your command works the way you expect using the Parameters button.
            Before the button will show up, you'll need to enable parameters on your command:
            Then when you click this button:
            You should have a phrase that ends with X.
            When you talk to Alexa, you say your parameter in place of X.
            Here's a video I made a while ago about how it works with Alexa:
            https://www.youtube.com/watch?v=P6m9gJIsuxE
              Felipe Guedes
              @Russ I dont know why, but de command doesn't execute NODE command.
              Can you explain to me what i need to do?
                Felipe Guedes
                When i run with parameters, it mark that command is run, but to my nothing happens.
                  Russ @Felipe Guedes
                  @Felipe-Guedes, the best way to troubleshoot is make sure it works from a cmd prompt first. If you get an error running the node command at the cmd prompt you probably don't have nodejs installed yet.
                  After you get it working from the cmd prompt, then add it to the TRIGGERcmd agent and include the parameters in the command field at first.
                  This is boss baby example is actually pretty complex to implement, and I realize I didn't include all of the steps. I'm going to be busy this 4th of July weekend but after that I can make a more detailed video if you want.
                    Felipe Guedes
                    Tks @Russ ,
                    The command in node runs very well, but when i try to run in trigger cmd in my windows doenst run, when i try to run by the website, it shows me it did, but it didn't.
                      Russ @Felipe Guedes
                      @Felipe-Guedes, what is your command? And does that same command work if you run it in a Windows cmd prompt?
                        Felipe Guedes
                        Yes my command runs very well.
                          Russ @Felipe Guedes
                          @Felipe-Guedes, it works from the cmd prompt but not from TRIGGERcmd? If so, maybe in your cmd window you're running it from the directory where the script resides, so the problem with running it via TRIGGERcmd is that the working directory is not where the javascript file is. In which case, you could either create a batch file that changes the working dir to that folder before running the node command, or it might be adequate to specify the full path to the .js file as part of your command like this:
                          node c:\scripts\scriptdir\script.js
                            Felipe Guedes
                            Yes, i know that.
                            Thats my configuration:
                            "trigger": "abrir google",
                            "command": "node C:\Users\Artista\Documents\node_modules\selenium-webdriver\exemple\google.js",
                            "ground": "foreground",
                            "voice": "abrir google",
                            "voiceReply": "",
                            "allowParams": "true"
                            And the full path:
                            When i run directly in cmd, runs very well like i said, but in trggercmd no.
                              Russ @Felipe Guedes
                              @Felipe-Guedes, thanks for that info. That helps.
                              I'm still thinking it's a problem with the working directory. Node knows how to find module dependencies based on the working directory. Would you mind trying this?
                              Create a script called c:\scripts\google.bat with these contents:
                              cd /d C:\Users\Artista\Documents\node_modules\selenium-webdriver\exemple
                              node google.js
                              Then make this your triggercmd command: c:\scripts\google.bat
                                Felipe Guedes
                                Perfect, now i can execute the command in trigger cmd and i have other problem hhahahahah.
                                When i say - "Alexa, Execute comando" -> "Execute automacao com parametro boss baby" -> She don't recognize my command. Isn't an exemple with parameters in portuguese.
                                Help me, we almost there !
                                  Felipe Guedes @Felipe Guedes
                                  @Felipe-Guedes Otherwise, is this configuration set maximized chrome.
                                  var chrome = require("selenium-webdriver/chrome");
                                   * Set chrome command line options/switches
                                  var chromeOptions = new chrome.Options();
                                  chromeOptions.addArguments("test-type");
                                  chromeOptions.addArguments("start-maximized");
                                  chromeOptions.addArguments("--js-flags=--expose-gc");
                                  chromeOptions.addArguments("--enable-precise-memory-info");
                                  chromeOptions.addArguments("--disable-popup-blocking");
                                  chromeOptions.addArguments("--disable-default-apps");
                                  chromeOptions.addArguments("--disable-infobars");
                                  var driver = new Builder()
                                      .forBrowser('chrome')
                                      .setChromeOptions(chromeOptions)
                                      .build();
                                  I'm still searching how to set full screen in video, and how to stop and play.
                                  i'll post here when i find
                                    Russ @Felipe Guedes
                                    @Felipe-Guedes, does this work?
                                    Alexa, pergunte Execute Comando execute automacao com o parâmetro boss baby.
                                    I think I need to fix the portuguese text on the voice command cheat sheet page.
                                    EDIT: I updated that voice command cheat sheet page. I hope that works better.
                                    Felipe GuedesF 1 Reply Last reply Reply Quote 0
                                      Felipe Guedes @Russ
                                      @Russ it's doesn't work.
                                      No problem
                                        Russ @Felipe Guedes
                                        @Felipe-Guedes, what does Alexa say back to you?
                                          Felipe Guedes @Russ
                                          @Russ I try to say in this order:
                                          Alexa, Abrir Execute Comando
                                          Alexa, Execute automação com parâmetro boss baby
                                          Alexa says: Diga algo como execute a calculadora no laptop, você também pode dizer para se já estiver terminado.
                                          Other way:
                                          Alexa, pergunte Execute Comando executar automação com o parâmetro X.
                                            Russ @Felipe Guedes
                                            Thank you @Felipe-Guedes! That helps. I found and fixed one problem so far:
                                            I said, "Alexa, pergunte Execute Comando executar calculadora." and Alexa sent this to my server, which is wrong. The value should have been calculadora, not comando calculadora.
                                              "name": "Trigger",
                                              "value": "comando calculadora",
                                            I've had this problem before. Alexa sends extra words in the trigger field. I fixed that, but I'm not sure that's the problem you were having.
                                            After that it worked for me. I said, "Alexa, pergunte Execute Comando executar automação com o parâmetro boss baby" and it ran my command and passed "bos baby" as the parameter.
                                            This is my test command:
                                            Will you please test again and tell me if that helped?
