    Ctrl+W closes Chrome entirely instead of just a single tab
    1.9k
    • kellanistK
      kellanist
      Created a vbs to close a tab in Chrome using Ctrl+W.
      Dim Wsh
      Wsh.SendKeys "^{W}"
      When I run it, it closes the entire Chrome window instead of just the single tab and I have no idea why.
      • kellanistK
        kellanist
        @Russ any ideas on how to direct the command at the Chrome window?
          Russ @kellanist
          @kellanist, I don't know why CTRL+W closes Chrome, but I did find that CTRL+F4 works to close a single tab:
          Dim Wsh
          Wsh.SendKeys "^{F4}"
          • kellanistK
            kellanist @Russ
            @Russ That worked brilliantly!!!! It also solved another issue I had been having. When programming a button on my Logitech keyboard, Ctrl+W wouldn't "select" the Chrome window again after it closed the tab. Ctrl+F4 worked much better than Ctrl+W.
            THANK YOU!!! Now I feel like I'm on the Enterprise. I can just yell at the computer to do everything.
              Russ @kellanist
              @kellanist, sweet! I'm glad that worked out.
