Re: Open Specific Netflix Movie with Alexa
So, I am a beginner with all of this, but can learn quickly. My first problem is that I am not 100% sure i did step 4 correctly in the forum linked, I dont know where to put the "chromedriver"(executable) and how i should have my PATH variables set up. Second, when I think I have it figured out, I get "Syntax error Code: 800A03EA Source: Microsoft JScript compilation error" every time.
I believe I have everything downloaded and installed that I need, the problem is I cant run it.
Please help, I'd love to figure out how to do more things with my alexa.
Thanks -
@bignoob, does it work if you run the command yourself, in a cmd window?
You can copy that chromedriver exe into a new folder, then add that folder to your PATH environment variable, or just copy the exe into C:\windows folder which is already in your PATH by default.
