    trigger cmd on arch linux
    19 Posts 4 Posters 5.6k Views 1 Watching
    • Terry KingT Offline
      Terry King
      is there a way to get trigger cmd running on arch linux? i see there is a linux agent however .deb is debian based distros and rpm i beleive is what ever fedora is based on. i use manjaro which is arch linux with a noob friendly installion (lol) and uses pacman to install which does not allow for the installion of .rpm or .deb files
      any help would be appreciated.
        Russ @Terry King
        Hey @Terry-King, I'll look into it.
          Russ @Terry King
          @Terry-King, I'm not planning to make an archlinux package, but you could install the agent from the Github repo like this:
          pacman -Sy
          pacman -S nodejs npm git
          cd TRIGGERcmd-Agent
          npm install
          node ./src/agent.js --console
          Terry KingT 1 Reply Last reply Reply Quote 0
            Terry King @Russ
            @Russ will it work as well as on windows?
              Terry King @Terry King
              @Russ here is a recording of my terminal output when i run those commands https://asciinema.org/a/xxStYX1LqovlHqvpDsf3vuY6G
                Russ @Terry King
                @Terry-King, you were close. You can generally ignore those warnings when you run npm install. So you probably just had to run this when you were in the TRIGGERcmd-Agent folder:
                You're not running X Windows right? That command runs the agent in forground mode and doesn't give you the tray icon or the GUI command editor, so you'll have to edit your ~/.TRIGGERcmdData/commands.json file with a text editor.
                  Terry King @Russ
                  @Russ uhm i honestly dont know. here is my neofetch if that helps link text
                    Russ @Terry King
                    @Terry-King, I think it will work if you try again, and just run this command:
                      Terry King
                      ok i got the app installed (it asked me for my token) but there isnt a GUI? how do i set up commands?
                        Russ @Terry King
                        @Terry-King, no GUI when you run it that way.
                        You have to edit the ~/.TRIGGERcmdData/commands.json file to add commands.
                          Terry King @Russ
                          @Russ is there a video that shows how to do this?
                            Russ @Terry King
                            @Terry-King, no, but that's a good idea. I'll work on that - hopefully tomorrow.
                            EDIT: It's done: https://youtu.be/Iv6ifjHyWF4
                            • Tiago MártiresT Offline
                              Tiago Mártires
                              Thank Russ for this , but on arch how I run the triggercmd on boot?
                              my goal is wakeonlan....
                              thankyuo
                                Russ @Tiago Mártires
                                @Tiago-Mártires, I answered here: https://www.triggercmd.com/forum/topic/625/boot-on-arch
                                • M Offline
                                  mayron
                                  @Russ said in trigger cmd on arch linux:
                                  Sorry to open again this topic, but when i call 'npm install' this error showed and close the build:
                                  npm ERR! notsup Unsupported platform for node-windows@0.1.14: wanted {"os":"win32","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                  I think strange, because, the win32 appear... but i use manjaro..
                                    Russ @mayron
                                    @mayron, thanks for reporting this.
                                    The package.json that's in-place now might be the windows version. Please try copying the ubuntupackage.json or redhatpackage.json file over-top of package.json like this:
                                    cp ubuntupackage.json package.json
                                    Then try npm install again.
                                    I don't have time right this minute to test it. I'll add a archbuild.sh file to that repo once I know which package.json works.
                                    • M Offline
                                      mayron @Russ
                                      @Russ thanks for the answer, now it made the correct build, but i remember that in ubuntu request for the token when I call the command .. here's the message below
                                      $ node ./src/agent.js --console
                                      Daemon install: false
                                      prompt: token:  (node:369045) Warning: Accessing non-existent property 'padLevels' of module exports inside circular dependency
                                        Russ @mayron
                                        @mayron and I talked over chat and it's working for him now. I tested it too. We just had to press enter at that Warning prompt, then paste in the token. I'll try to get rid of that warning, but at least it works as-is.
                                        I think one of the packages was updated to the latest version which introduced that warning message.
                                        • M Offline
                                          mayron @Russ
                                          @Russ thanks!
