    Can't add command with raspberry pi 3b+
    9 Posts 2 Posters 2.5k Views 1 Watching
    • P Offline
      Phuong Dinh
      Re: Raspberry Pi setup
      I have tried opening the commands.json file and add
      {"trigger":"shutdown","command":"shutdown now","ground":"background","voice":"shutdown","allowParams": "false"}
      inside the parameters. However, the command does not show up on the website; and when I tried to execute the shutdown command through Alexa, it just beeped and did nothing. Can somebody help me with this problem?
      P.S: It does work with the original commands.
        Russ @Phuong Dinh
        @phuong-dinh,
        I'm glad you told me it works with the original commands. These are the original commands:
          {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
        Can you paste your commands.json file here?
        If the Reboot command works, then could you just try changing that to shutdown now instead of shutdown -r
        Also - just to make sure you know - you need a comma at the end of any line except the last one.
        • P Offline
          Phuong Dinh
          Below is the full commands.json file; it is under /home/pi/.TRIGGERcmdData.
          Even when I changed the original reboot command to shutdown. The system still reboots.
          {"trigger":"Reboot","command":"shutdown -P now","ground":"background","voice":"reboot","allowParams": "false"},
            Russ @Phuong Dinh
            @phuong-dinh, I suspect the commands.json file that you're actually using might be /root/.TRIGGERcmdData/commands.json. Can you check that?
            • P Offline
              Phuong Dinh
              Okay, I was editing the wrong file all along. Now I do see my trigger online, and I can activate it. However, I still can't tell Alexa to execute the new command. Once again, Alexa just beeped and then nothing happened. So right now this is what I have under /root/.TRIGGERcmdData/commands.json.
                Russ @Phuong Dinh
                @phuong-dinh, ok, that's progress at least.
                You could try unlinking and re-linking your Alexa account to your TRIGGERcmd account.
                Also, what exactly are you saying to Alexa?
                • P Offline
                  Phuong Dinh
                  Unlinking the Trigger CMD with Alexa doesn't seem to help.
                  My conversation with Alexa is like this:
                  Me: Alexa, open Trigger CMD
                  Alexa: Say something like: open calculator on ...
                  Me: Shutdown Magic Mirror (Magic Mirror is the name of the device)
                  Alexa: Beeped... and nothing happen.
                    Russ @Phuong Dinh
                    @phuong-dinh, saying "shutdown magic mirror" is not a valid phrase for TRIGGERcmd.
                    Please try saying these:
                    Alexa, open TRIGGERcmd, (wait for the prompt), run shutdown.
                    Alexa, ask TRIGGERcmd to run shutdown.
                    Alexa, ask TRIGGERcmd to run shutdown on magic mirror.
                    • P Offline
                      Phuong Dinh
                      Okay, the command lines you provided work, and I also changed my command word to just "shut" so Alexa can recognize it better. Overall, thanks a lot for helping me, TriggerCMD is definitely a great tool for the raspberry pi.
